help with mystery engine noise - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 09-10-2011, 06:14 PM Thread Starter
Quoted: 0 Post(s)
2003 SE7; 68,000 miles
Have a mystery engine noise that I'm trying to diagnose.
Symptoms:
rapid, metallic squeaking/chattering
varies with engine speed
present under load / heavy load
disappears at idle / light load
recent work: all drivetrain fluids changed; coolant changed (still using dexcool); plugs and wires changed; air filter changed
engine does not appear to be losing any fluids
any ideas???
cheers
jakked is offline
post #2 of 9 (permalink) Old 09-11-2011, 06:01 AM
Administrator
Quoted: 5 Post(s)
Does it happen both hot and cold, have you inspected your front drive shaft, does it has 3 grease fittings, 1 on each u-joint?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 9 (permalink) Old 09-11-2011, 06:07 AM
94svt50's Avatar
Quoted: 1 Post(s)
Are you using premium gas? What you are describing sounds a bit like detonation.
'03 discovery HSE-7
'02 pathfinder
'89 yota 4x4
94svt50 is offline
post #4 of 9 (permalink) Old 09-11-2011, 06:16 AM Thread Starter
Quoted: 0 Post(s)
93 octane;
original u-joints; visual inspection of DS seems fine, but I'm not sure if I'm looking for something in particular;
sound is engine speed dependent, not vehicle speed dependent. could it still be a DS problem then?
Question: would a leaky head gasket possibly cause this sound? I think I may be losing a little coolant.
EDIT: happens both hot/cold; cannot reproduce sound in neutral or idle; only under load.
jakked is offline
post #5 of 9 (permalink) Old 09-11-2011, 07:08 AM
mbruneaux's Avatar
Quoted: 5 Post(s)
Exhaust leak?
Canterbury, CT
1989 Chrysler Conquest TSi (Project Race Car)
2001 Pontiac Grand Prix GTP (Daily Driver)
2002 Discovery II SE7 (Wife's progeny wagon and tow vehicle)
Second place is S*** place , eh. - Stéphane Peterhansel
mbruneaux is offline
post #6 of 9 (permalink) Old 09-12-2011, 10:14 AM
'03 Disco SE
Bosnian Discovery's Avatar
Quoted: 12 Post(s)
Check your belt/tensioner. A worn tensioner, idler, or belt can definitely make the "metallic squeaking/chirping" noise you describe. Check the condition of the belt of cracks and fraying and check to see what kind of give you get when you press your thumb on the belt.
Could be exhaust leak but those generally "tick".
Bosnian Discovery is offline
post #7 of 9 (permalink) Old 09-12-2011, 01:32 PM
Quoted: 0 Post(s)
I had a similar occurance which turned out to be a generally loose connection between the driver's side exhaust manifold and the Y pipe. I was able to tighten the nuts on the studs a full turn in two cases, and the third was/is snapped off [replacing the stud and gaskets is my next DII adventure]. IIRC, the nut is a 13mm socket size.
scout_beagle is offline
post #8 of 9 (permalink) Old 09-12-2011, 07:40 PM Thread Starter
Quoted: 0 Post(s)
the advice is much appreciated.
the belt seems in great condition; however I can confirm that I have at least one leaky head gasket (visual confirmation).
I don't know about loose manifold bolts, but I'm sure that when I tear it down to replace the head gaskets I'll make sure all the bolts are tightened to spec. All the gaskets from the head up and all the bolts will be addressed, so hopefully when it's all back together the sound will have gone away.
jakked is offline
post #9 of 9 (permalink) Old 09-14-2011, 04:43 PM
007
2004 Discovery SE
007's Avatar
Quoted: 0 Post(s)
Front driveshaft noise
Jakked, my bet is on the driveshaft. There is much info in regards to the nasty outcome of not replacing the U-joints with a greasable joints. You state that the U-joints are original with 68,000 miles on her. Do yourself a favor and have the front driveshaft serviced, and your noise will disappear..............................007
1964 Chevy Impala/ sold
1968 Chevy Camaro RS/ sold
1967 Jeepster Commando/ sold
1968 Jeepster Commando/ sold
1969 Jeepster Commando/ sold
1970 Jeepster Commando/ sold
1974 J20 Jeep Pickup sold
1982 J20 Jeep Pickup sold
1971 350 SL/ 4 speed stick/ sold
1979 300 CD/ sold
1979 450 SL sold
1985 300 D/ sold
1989 560 SL/ sold
1996 Isuzu Hombre/ sold
1994 E320 Wagon/ sold
1995 SL500/ 46,000 miles/ sold
2004 Land Rover Discovery SE sold
2009 SL550 Silver Arrow Edition 22,000 miles
2013 SL550 With every option- Tenorite Gray /Red
007 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Mystery whistling noise - HELP! inganina Range Rover P38, Mk III and Range Rover Sport 5 09-10-2009 12:51 AM
Loud mystery whistle noise - help! inganina Range Rover P38, Mk III and Range Rover Sport 1 07-22-2009 07:02 AM
Mystery Noise Greg M Range Rover Classic 6 08-10-2007 09:45 AM
mystery noise HALLIDAY Discovery Series II 3 12-16-2005 02:01 AM
Mystery engine component O.B. Discovery Series II 0 09-05-2005 12:42 PM
You may post new threads
You may post replies
