How To: Replace Shuttle Valve Seals - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 07-01-2011, 06:59 PM Thread Starter
jycsalas's Avatar
Quoted: 1 Post(s)
Exclamation How To: Replace Shuttle Valve Seals
Finally!
ABS SVS Seals - LAND ROVER CLUB V.I.
Enjoy!
~Josh
2003 Discovery S (64k miles)
Mods: Oil Pressure Gauge, ScanGaugeII, CDL, Electric CDL Actuator, RoverRacks Rear ladder, Limb Risers, ToddCo Front Drive Shaft, DI Wiper Arms, G4 Upper Rear Lamp Guards, No Amigos since 11/09
Coming soon:
Install Greg Davis rear bumper, Replace 4 ball joints, Replace belt tensioners and pulleys.
For the future:
.... wait and see....
jycsalas is offline
post #2 of 6 (permalink) Old 07-01-2011, 07:07 PM
Mr. t
MR.T's Avatar
Quoted: 0 Post(s)
Damn, I definitely put mine in the wrong place. Looks like you were right about the thing with purple o rings. I must've pulled out the shuttle valve and the sleeve that encases it. That's why I couldn't find my old seals. Good work though.
Falconworks was wrong I guess, that is the location of the shuttle valves.
\;/ complete rhino coat interior/MP3 converter(removed 6 disc)/Scan gauge II/2" RTE lift/terrafirma +2 shocks/terrafirma damper/RTE tie rod and drag link/tom woods front drive shaft/97 DI CDL/ K&N filter/RTE wide face front bumper/ SD roof rack and rear ladder/goodyear duratrac's 285/75/R16's/Brembo rear rotors and Will Tillery super secret brand front rotors/ Akebono Euro's all the way around/extended stainless brake lines/saudi spec grille/DI wipers/option "B" amigo free/ And Getting Badder Asser as the days go by\;/
MR.T is offline
post #3 of 6 (permalink) Old 07-01-2011, 07:42 PM Thread Starter
jycsalas's Avatar
Quoted: 1 Post(s)
Im sure there was miscommunication. The two center hex caps are absolutely nothing it's just a hex cap with a hole to a blank in the body. Check ur email!
~Josh
Coming soon:
For the future:
jycsalas is offline
post #4 of 6 (permalink) Old 05-05-2017, 01:00 PM
wmsimpson's Avatar
Quoted: 4 Post(s)
Originally Posted by jycsalas View Post
This link is dead. It now points to LandRoverUSA.com, which isn't helpful. I'm about to do the shuttle valve seal replacement and sure would like to know what I'm up against.
Anyone?
wmsimpson is offline
post #5 of 6 (permalink) Old 05-05-2017, 01:35 PM
Quoted: 531 Post(s)
CT090 is offline
post #6 of 6 (permalink) Old 05-05-2017, 01:40 PM
wmsimpson's Avatar
Quoted: 4 Post(s)
Thank you for the reply, but this shows you how to replace the shuttle valve switch assembly, not the shuttle valve seals (which leak and cause the switches to fail). I have, however, found where the Land Rover Club V.I. site has gone to, and located the section on replacing the seals. It is located here:
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
abs shuttle valve seals? please help? MR.T Discovery Series II 11 02-23-2012 07:03 PM
Need help with ABS Shuttle Valve codes clayrobinson Discovery Series II 5 06-27-2011 05:08 PM
Need D-II Abs Shuttle Valve Switch... 2000-Disco Land Rover Parts and Vehicles Wanted 1 12-29-2010 06:45 PM
Shuttle valve scotth Discovery Series II 4 09-08-2008 06:00 PM
Shuttle Valve murray.richardt Discovery Series II 1 06-06-2008 07:43 AM
You may post new threads
You may post replies
