Intermittant AC blower - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 18 (permalink) Old 08-31-2018, 04:16 PM Thread Starter
Quoted: 88 Post(s)
The Mrs said her ac blower in the D2 doesnt come on - itermittantly.
(Although she didnt use the term “intermittantly” ha!)
Any thoughts?
sobieski is offline
post #2 of 18 (permalink) Old 08-31-2018, 05:19 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Bad contact, usually on the F7's circuit in the interior fusebox, read this whole thread: https://www.landroversonly.com/forum...t-blow-130737/ cos the troubleshooting steps are there
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 18 (permalink) Old 09-02-2018, 05:24 AM Thread Starter
Quoted: 88 Post(s)
Thanks Sierra.
sobieski is offline
post #4 of 18 (permalink) Old 09-09-2018, 01:24 PM Thread Starter
Quoted: 88 Post(s)
Fuse in box under steering wheel was pristine.
Put it back in.
Worked fine.
Hmmmm.
sobieski is offline
post #5 of 18 (permalink) Old 09-10-2018, 12:51 PM
Bleeds Green
discovering's Avatar
Quoted: 25 Post(s)
Garage
I've had that happen in the past when the blower motor was going bad.
2014 Range Rover Sport HSE
2006 Range Rover Sport Supercharged
2004 Discovery SE7
2003 Discovery S7 (sold)
What do you call a Land Rover that doesn't leak? Empty.
discovering is offline
post #6 of 18 (permalink) Old 10-09-2018, 12:16 AM
Quoted: 0 Post(s)
This was happened to me last year, very annoying...
jacksonroy is offline
post #7 of 18 (permalink) Old 10-11-2018, 05:06 AM Thread Starter
Quoted: 88 Post(s)
Jackson, what was your fix?
sobieski is offline
post #8 of 18 (permalink) Old 04-28-2019, 10:23 AM Thread Starter
Quoted: 88 Post(s)
Picking this one back up....
I did the fuse bypass but the fan blower is still intermittent.
If she puts the blower on set to Non-recycled air, it typically comes on after driving a few minutes.
Relay?
Any direction ( Fery ) on diagnosing “from the top” would be appreciated.
With your direction I can practice what I learned from the window motor and electrical library experience.
Thanks!
sobieski is offline
post #9 of 18 (permalink) Old 04-29-2019, 12:35 AM
sierrafery's Avatar
Quoted: 246 Post(s)
How did you do the fuse bypass? piggiback from F7 to the blower's plug or how
Try to set the blower to maximum speed and see then, if it's not intermittent on max speed only on all the others then the problem is with the power transistor or it's circuit, to rule out other circuit issue make somehow to hook two wires to the blower's plug pins(C0056) bring them on the dash and let a voltmeter connected to them while the symptom occurs, white/red wire is (+)... if there is voltage while the blower doesnt work the problem is with the motor, if the voltage is missing too you'll have to see what's missing so let positive voltmeter probe hooked to the WR wire, connect the other to earth somewhere and see then and report the results and we'll speak again cos this troubeshooting must go step by step and it's hard to cover all the possibilities from the beginning
post #10 of 18 (permalink) Old 05-01-2019, 04:24 AM Thread Starter
Quoted: 88 Post(s)
Will do.
The intermittent issue is present w the fan blower set to Hi, which tells me it’s not the resistor. ✅
I just need the blower to be not working and the truck and me at the house all at the same time to test the voltage at/from the connector. ✅ (maybe i could fab something up for the mrs to tell me when she’s out and about).
Will report back.
Thanks..
sobieski is offline
post #11 of 18 (permalink) Old 05-04-2019, 03:52 PM Thread Starter
Quoted: 88 Post(s)
I have 12v going to / at the plug at C0056, on the highest fan speed setting; yet, no blower blowing.
Thus, does that conclude that it's as simple as a new blower motor?
Could it be that easy?
sobieski is offline
post #12 of 18 (permalink) Old 05-04-2019, 05:15 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Yes, as long as it's good contact in that plug and the pins are not loosened cos as you see that plug is connected directly to the motor and while it's power there the motor should run.
post #13 of 18 (permalink) Old 05-06-2019, 05:19 AM Thread Starter
Quoted: 88 Post(s)
I’ll get the new blower ordered.
Thanks!
sobieski is offline
post #14 of 18 (permalink) Old 05-06-2019, 06:40 AM
Quoted: 59 Post(s)
Thanks!
I have a used spare if you want to test Mike - if it'll work for you bro. Just give me a call and you can swing by for it bro.
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #15 of 18 (permalink) Old 05-06-2019, 08:44 AM Thread Starter
Quoted: 88 Post(s)
Thanks Mike!
The replacement is already en route, but good to know you have a "parts" shelf - I may circle back to see what goodies you have laying around, when needed!
sobieski is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Intermittant Start Problem DiscoBarry Discovery Series II 5 05-05-2011 06:56 AM
Not starting "M" and "S" light flashed, Intermittant starting problems skylark27 Discovery Series II 26 01-10-2010 09:12 PM
AC Fascia for Wynn's blower- D90 AC aosias Land Rover Parts and Vehicles Wanted 0 01-05-2010 09:12 PM
Intermittant Starting Problem... 9dawgs Discovery Series I 25 10-10-2006 05:33 PM
help i love her but theres an intermittant starting problem new2rangies Range Rover Classic 2 12-24-2004 04:42 AM
You may post new threads
You may post replies
