Lifting an ACE equipped Disco - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 20 (permalink) Old 11-19-2009, 03:00 PM Thread Starter
Quoted: 0 Post(s)
I'm familiar with what ACE does, but not positive how it works. From what I've read it's an electronically and hydraulically control system that exerts onto the torsion bars to keep things stable. My question, does going to a coilover system (OME lift for example) require you to get rid of the ACE system? Or is it completely independent of the coil and shock?
DocSean is offline
post #2 of 20 (permalink) Old 11-19-2009, 03:15 PM
laments the death of industrial strength soup sporks \;/
Ultraviolet's Avatar
Quoted: 0 Post(s)
its a hydrolic piston on oppisite corners, passenger front, driver rear. one side of the swaybar. you can lift it 3 inches max for it to stay happy. it's what i've done as well as disco mike. i'm sure some others too.
I am the White Rabbit
Ultraviolet is offline
post #3 of 20 (permalink) Old 11-19-2009, 03:25 PM Thread Starter
Quoted: 0 Post(s)
Ok, great. So no technical challenges in installing a list, or any type of new suspension on an ACE equipped vehicle? I guess in my head I figured it had to tie into the shocks or air somehow. Not the case apparently?
DocSean is offline
post #4 of 20 (permalink) Old 11-19-2009, 03:33 PM
Quoted: 0 Post(s)
nope, not the case. no worries.
post #5 of 20 (permalink) Old 11-19-2009, 04:04 PM Thread Starter
Quoted: 0 Post(s)
Such is not the case with an SLS equipped vehicle since the rear uses airbags, correct? Does removing that equipment pose any challenges? I read about a lot of the headaches with the OEM bags.
DocSean is offline
post #6 of 20 (permalink) Old 11-19-2009, 04:05 PM
mbrummal's Avatar
Quoted: 0 Post(s)
It isn't hard to remove them you just have to disable the suspension with testbook to T4
This site sucks balls.
mbrummal is offline
post #7 of 20 (permalink) Old 11-19-2009, 04:06 PM
p76rangie's Avatar
Quoted: 385 Post(s)
Why would you want to remove it? You can still do a lift with SLS.
p76rangie is offline
post #8 of 20 (permalink) Old 11-19-2009, 04:21 PM
Quoted: 0 Post(s)
yea, i've kept mine. only one leaky bag in almost four years. bought a couple of spares to keep on hand. i wouldn't want to be without the air, comfy ride and always level no matter the load.
post #9 of 20 (permalink) Old 11-19-2009, 06:14 PM Thread Starter
Quoted: 0 Post(s)
Can you do all the standard lifts and maintain the rear air? I'm not familiar with the rear suspension setup on the disco. But my understanding of the lift kits like OME, is that they area coilover lift. Wouldn't this replace any current airbags?
DocSean is offline
post #10 of 20 (permalink) Old 11-19-2009, 06:26 PM
mbrummal's Avatar
Quoted: 0 Post(s)
You can get SLS spacers from Rovertym and use OME coils in the front and their shocks all around.
mbrummal is offline
post #11 of 20 (permalink) Old 11-20-2009, 04:48 AM
Steph's Avatar
Quoted: 0 Post(s)
I wouldn't swap the SLS until you have a problem with it. But at the very first sign of a problem though, I wouldn't hesitate 1 second to swap it to coils.
That's what I did and the peace of mind is priceless. Maybe it can fail once every 4 years, but it can be in the very worst of places, like in a ski lodge, hours away from home or the likes. This being a Land Rover, it is also one less thing to go wrong. Why not eliminate the known weeknesses when you can. I'd order a full 4 coils kit. That way when you do have a problem with SLS, and you will....You'll have the parts to do the swap. All you'll need is the spring bottom plates with bolts that the dealer keeps in stock (tells a lot right there doesn't it ?!?...) and coil isolators. But you will have saved by buying the kit instead of separate parts.
Ditto for no problem with ACE and an Old Man Emu 2 inch lift.
Knowledge is only really worth anything when its been experienced first hand. If you heard it from a guy who heard it from a guy.....nevermind and keep it to yourself.
[SIGPIC]
Steph is offline
post #12 of 20 (permalink) Old 11-20-2009, 05:18 AM
Administrator
Quoted: 5 Post(s)
Why not install a RTE 2" lift for the SLS and then it can be adjusted up to nearly 4"s if wanted.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #13 of 20 (permalink) Old 11-20-2009, 02:15 PM Thread Starter
Quoted: 0 Post(s)
That's great advice, and probably exactly what I'll look into doing!
I'm not familiar with RTE, I just know OME makes quality parts from a previous FJ install. In your opinion, RTE would be the route to go?
DocSean is offline
post #14 of 20 (permalink) Old 11-20-2009, 03:03 PM
Steph's Avatar
Quoted: 0 Post(s)
RTE make SLS spacers along with full suspension. OME make the most comfortable riding suspension. I never compared, but that's their reputation.
[SIGPIC]
Steph is offline
post #15 of 20 (permalink) Old 11-20-2009, 05:01 PM
Quoted: 0 Post(s)
Rovertym Engineering
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
LR parts, Disco, RRC TheDirtyRover Land Rover Parts and Accessories 4 11-20-2009 01:29 PM
supplies for lifting my 96 disco 2in plus 1in spacer? manieldunk Discovery Series I 1 05-01-2009 07:53 PM
Help - Lifting a Disco II DiscoIIoffroad Discovery Series II 4 10-13-2007 03:41 PM
lifting 02 disco 2 herness Discovery Series II 4 01-16-2007 04:22 AM
Pre-95 Disco Newbie needs more advice pfkb72 Discovery Series I 18 09-12-2005 08:49 AM
You may post new threads
You may post replies
