Location of knock sensor: left or right, front or rear of block? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 05-29-2019, 06:26 AM Thread Starter
Quoted: 4 Post(s)
I'm keeping my son's D2 for the summer.
Been 4+ years since he and I (mostly he), pulled engine to have flanged liners installed and rebuild the engine (friend of his' father gave the D2 to my son after it slipped a sleeve).
Haven't been under it since then.
I am getting a P0332 (knock sensor bank 2) code, as well as P0505 (IAC) and P0441 (infamous purge valve -- my son says he that when this code comes up, he first flushes the valve with brake cleaner, then WD40 and it's good for another 6-12 months).
The vehicle did experience a bit of pinging (rattling?) under acceleration when the code first popped up, but not since after driving it a couple of short trips. Really scared me, sounded like a like a high-ish frequency (5-10 cycles/sec) body/heat shield type of rattle but clearly emanating from the engine. Was worried maybe it might be a collapsed lifter but no ticking or other sounds in the rocker covers or elsewhere on the block when using a mechanics stethoscope to listen, and otherwise it purrs like a kitten at idle after the air pumps shuts off.
Re. the knock sensor code:
1. I recall there was only 1 knock sensor on the block (am I right? if so, so why a bank 2 code?); and
2. It was located toward the back of the block on the bank 1 side (1357 cylinders, LH or drivers side).
Again, been a long time since I crawled under the beast, so wanted to get oriented before I get on my back and do a visual inspection -- it seems the wiring on these things breaks not too infrequently.
Any quick orientation on the knock sensor location and any experience with the code itself would be appreciated (maybe the mating/contact surface with the block just needs cleaned or the bolt tightened? or once this pops up, just get a new sensor?)
austindiscoverybill is offline
post #2 of 3 (permalink) Old 05-29-2019, 07:21 AM
Quoted: 59 Post(s)
The ECM uses two knock sensors. You need to crawl underneath and look up on the block on both sides. They are located between the center two cylinders of each bank.
At least they are on my Bosch...
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #3 of 3 (permalink) Old 06-03-2019, 04:05 AM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 10 Post(s)
https://www.roverparts.com/Instructi...KnockBOSCH.cfm
MIKE
- 2001 Discovery 2 SE (NAS LHD) “MYRTLE”, 110K miles, 4.0L V8, NGK Iridium IX plugs, PCV mod, 180* T-stat, Hayden fan clutch/Dorman fan, removed TBH, SAI modded K&N filter, Safari Gard steel guards, Warn XD9000i winch, KO2 265/75R16 on steel rims, EBC rotors/Akebono pads, +2” TF lift & LEDs
- UltraGauge Blue, Foxwell NT510, Nanocom D2 V8 & TD5
JUKE179r is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
