Major Service For High Milers Over 90,000 Miles - Land Rover Forums : Land Rover and Range Rover Forum
 7Likes
post #1 of 50 (permalink) Old 09-25-2010, 06:30 AM Thread Starter
Administrator
Quoted: 5 Post(s)
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil, Shell Rotella T-6
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
6 Qts. Of Vavoline’s high mileage Dextron 3 ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of Castrol Synthetic or Vavoline’s DOT 4 Brake fluid
4 Qts of synthetic Power steering fluid
2 Gallons of Peak or any green or yellow coolant, don’t use Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of B&G’s 44K gas additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant Pressure Cap and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Rebuild or Replace the front drive shaft if it only has 1 grease fitting
Hopefully I didn't leave anything out.
david013 and nuovrlnd3r like this.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #2 of 50 (permalink) Old 09-25-2010, 06:53 AM
prettynpink1029's Avatar
Quoted: 2 Post(s)
Thanks for the sticky thread.
-Heather
prettynpink1029 is offline
post #3 of 50 (permalink) Old 09-25-2010, 07:15 AM
antichrist's Avatar
Quoted: 3 Post(s)
Service Intervals check sheet
Here's the list of items for the most major service from the manual
I wouldn't renew the cats unless it's needed.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
74 Lightweight - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
antichrist is offline
post #4 of 50 (permalink) Old 09-26-2010, 08:55 AM
Mr. t
MR.T's Avatar
Quoted: 0 Post(s)
can you guys explain the induction cleaning, engine flush and throttle body cleaning?
i've done everything but the aforementioned and the t-case. i can't get the damn fill plug out!
MR.T is offline
post #5 of 50 (permalink) Old 09-26-2010, 10:25 AM
Quoted: 11 Post(s)
Engine flush? WTF? The only thing to put in the sump is clean oil. If it's dirty, change your oil more frequently.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
PTSchram is offline
post #6 of 50 (permalink) Old 11-29-2010, 02:06 PM
Quoted: 0 Post(s)
pt, i be the first to tell u that: u can do and engine flush...ok so i was doing a trans flush using an machine..yeah yeah I know im an idiot.. well i grab the oil cooler line instead of the trans line.. long story short, motor had a good merk V flush. hahaha.. i kept thinking," how come the trans fluid is soo thick and black" lolol .. as techs, you know we all have our funny stories to tell.. i figured i share that with you..
moointhahouse is offline
post #7 of 50 (permalink) Old 12-11-2010, 07:19 PM
Volvo240Nut's Avatar
Quoted: 0 Post(s)
Great List / Guide to go by
Thanks!
1994 RRC LWB - Tow Rig / Winter driver
1980 Volvo 245 - Daily driver
1971 Volvo 164 - Wife's show car
1950 Nash Statesman - My show car
Volvo240Nut is offline
post #8 of 50 (permalink) Old 12-27-2010, 08:00 AM
Quoted: 0 Post(s)
Mike, why is it bad to use Dexcool?
Thanks,
Chris
kneehurts is offline
post #9 of 50 (permalink) Old 01-14-2011, 04:04 PM
Quoted: 0 Post(s)
Engine Oil Selection
On my DII and P38 (2001 & 2002) - I use Mobil 1 Full Synthetic High Mileage 5W30 in winter, Same make 10W 30 in spring and fall, and Mobil 1 Full Synthetic High Mileage 10W 40 in summer - I live in GA. I use a Mobil 1 301 filter always.
Are these sensible choices - I have no leaks and get great quiet running engines and performance - BUT I'd like to know if I an doing the right thing.... It would be nice for these to keep going for a long time, (DII has 81K and P38 88K)
BTW - AUTOZONE in GA have a special until Sunday - 5 Quarts of Mobil 1 High Mileage Full Synthetic and get a free Mobil 1 oil filter free - Total price $24.95 !!!! I stocked up with 10W40 and 301's :-)
Andy
Andy Ellis is offline
post #10 of 50 (permalink) Old 01-14-2011, 04:13 PM Thread Starter
Administrator
Quoted: 5 Post(s)
Dexcool may be the reason our D2's have been eating up head gasket faster the the D1's that don't use it. It also eats up out t/stat housings as well as the coolant caps.
operator707 likes this.
Need Parts?
Lucky8,
post #11 of 50 (permalink) Old 01-14-2011, 04:14 PM Thread Starter
Administrator
Quoted: 5 Post(s)
That oil combination is fine, some may also suggest Shell's Rotella synthetic.
Need Parts?
Lucky8,
post #12 of 50 (permalink) Old 01-17-2011, 06:06 AM
Quoted: 0 Post(s)
Oil
Thanks for the advice Mike - Experience and reassurance is awesome !!
post #13 of 50 (permalink) Old 01-17-2011, 01:37 PM
Quoted: 0 Post(s)
whoa...hold on....I thought we ``had to !!``use the orange Dexcool. What made you guys change your mind?......do we dump all the orange and go green??
piccanin is offline
post #14 of 50 (permalink) Old 03-13-2011, 08:13 AM
2003discoII's Avatar
Quoted: 1 Post(s)
the orange descool is no good.it leaves residue in the water pump and wears some parts out faster
2003 disco. exhaust mod,265/65r18
2003discoII is offline
post #15 of 50 (permalink) Old 03-15-2011, 09:40 PM
Quoted: 0 Post(s)
What about Dex/Merc? Says it is compatible as Dexron 3. My local parts store says Dexron 3 is a thing of the past.
Disco II Utah is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
DiscoMike
Linear Mode Linear Mode
D2 2001 21.000 miles flyboyaviator Discovery Series II 7 07-08-2010 07:38 PM
Major service, What fluids do i use??? akwagon Discovery Series II 5 03-02-2008 08:13 AM
95 ST For Sale $23,000 69k miles mlw911 Land Rover Vehicles 2 01-03-2008 06:42 AM
57,000 miles guitar588 Discovery Series II 13 10-26-2005 08:09 PM
In For Major Service AdrianL Range Rover Classic 10 01-26-2005 06:19 AM
You may post new threads
You may post replies
