Major Service For High Milers Over 90,000 Miles - Page 4 - Land Rover Forums : Land Rover and Range Rover Forum
 7Likes
post #46 of 50 (permalink) Old 07-09-2015, 11:55 AM
nuovrlnd3r's Avatar
Quoted: 1 Post(s)
Garage
Question Recommendations and tips?
New to the forum, not a Disco owner yet. I am in love with them and have started my search for he perfect '04 (new oil pump model). I was certified ASE in '93 (Chevrolet) and owned a VW tuner shop a few years back. I am no longer in the business, but certainly not afraid to wrench, and I know my way around a vehicle. Now, my plans after purchase are to replace ALL wear and tear items regardless of appearance as I was NOT there when they were replaced/covered in "ArmorAll". This will include ALL belts, hoses, brakes, brake lines, filters (air, oil and tranny), flush radiator, engine, tranny and service shafts if possible. I plan on lots of weekend, "get the hell out of dodge" trips off the beaten path. I live in the Appalachians so plenty of places to go. I plan on purchasing within 6 months and having outfitted in time for Appalachian Rendezvous 2016. I have to send wife and kid to London in December before purchase otherwise I would have one in my driveway now. This leads me to my questions as I am trying to set a budget ( I am aware it will be expensive). I do NOT cut corners (or try not to).
1. hoses - silicone or rubber and why?
2. shafts - replace if non-serviceable?
3. suspension - poly bushings? ( I know they squeak, will scuff)
4. lift - plan on 2" OME, how will this affect my drive shafts, will I need longer ones?
5. Sleeve drop prevention - ANYTHING beyond normal maintenance to prevent?
6. sensors - any need replacing due to time or miles that a non Rover mechanic wouldn't know about?
7. air filter - I noticed you said factory, do you NOT recommend K&N filter charger?
Any other tips you could share that I may have missed would be appreciated. And yes, it will be taken to LR dealer prior to purchase for inspection.
“There are only two days in the year that nothing can be done. One is called Yesterday and the other is called Tomorrow. Today is the right day to Love, Believe, Do and mostly Live.”
― Dalai Lama XIV
1999 Land Rover Discovery II
2008 Land Rover LR3 HSE
Last edited by nuovrlnd3r; 07-09-2015 at 12:01 PM. Reason: typo corrections and additional question
nuovrlnd3r is offline
post #47 of 50 (permalink) Old 07-20-2015, 07:22 PM
Stupid > Ignorant
Quoted: 0 Post(s)
Silicone hoses are porous. Hence they are not the best when used for fuel or coolant. Charged air is different story.
All driveshafts are serviceable. Someone had to build them right? I had my factory driveshaft rebuilt with grease fittings on the U joints. It has been about 8 years since I had them rebuilt. I grease them every other oil change interval. My front shaft has about 90K miles on them, I just drove 3000 miles in the past week or so.
I would never put poly in any of my daily driver. Been there done that. I put one on my Daily Driven Jeep in the past, and I put a transmission mount on, took it for a spin, I took it out the same day. There is hardly any give on poly bushings. It puts stress on other hardware. I'd rather change out the bushing then failing strap/bolt/bracket.
As far as I can tell, 2" is the limit where you can get away with just the lift.
When I bought my D2 back in 2008, I was told that I will be spending as much to keep the vehicle running and possibly more. I wouldn't say it was totally care free ownership but many things were exaggerated. I do 99.9% of the work on the vehicle that own. The jobs include doing oil pump in the front engine cover, timing chain, setting ring and pinion... I bought the truck and immediately after spent some money doing belts, pulleys, fluid change, new radiator, oil pump, replaced oil pan seal. During the past 7 year ownership, I replaced: RR hub, ABS sensors, alternator, battery, PS pump, two sets of plugs and wires.
Only used, good synthetic blend or fully synthetic for the oil change with interval of about 5000 miles. Knock on wood, but I have not had any trouble with the motor and it has 150K miles
Still have Dexcool in the radiator. I didn't know there was big fuss about it. I will be draining it in the next few days.
I think a lot of LR owners are absolutely clueless about cars in general and they think because a Rover is built for offroad that it is incredibly tough hence it does not require any maintenance. When in fact, because it has so many more moving parts, that it requires more extensive maintenance.
When sensors go bad, they throw a code.
MAF probe gets coated with K&N oil and can be irreversibly become faulty.
nuovrlnd3r likes this.
DailyDrivenTJ is offline
post #48 of 50 (permalink) Old 07-14-2016, 11:33 PM
LadyWitaRover
Quoted: 0 Post(s)
Hello
I have a question should I do all this before finding out what is causing the ticking in my 2003 Disco II? When I start my trick it sounds as if it's ideling to high, or it appears to be the ticking would gets some what louder the longer I drive that day. It only has 97,000 miles as well. Someone please help me figure this out.
Thanks
LadyNaRover is offline
post #49 of 50 (permalink) Old 07-16-2016, 11:48 PM
Jeff H. Reynolds's Avatar
Quoted: 2 Post(s)
Garage
LadyNaRover.... There are lots of threads in this forum that talk about the ticking sound that the engines can make. In my instance, the noise develops only when the engine is hotter than I would like... over 207 degrees. I have found that so long as the temp stays below that... I don't have the noise. I installed a new 180 degree thermostat, flushed the radiator, put a bottle of Luca's Super Coolant in and my truck has been running lots cooler than before and that sound has mostly disappeared. Don't simply trust the factory temp gauge. I use an OBDII tool that gives me exact sensor data (including temp) to my android phone. The cost was negligible.
Jeff H. Reynolds is offline
post #50 of 50 (permalink) Old 07-19-2016, 05:08 PM
LadyWitaRover
Quoted: 0 Post(s)
Thank you so very much Jeff for taking the time to explain I'm new to this forum. I had my husband a few weeks back install that 180 degree thermostat you referred to (pictures below of new Thermostat) I will tell him to flush the system again and then use the Luca's coolant as well. I did hear others say that the ODBll doesn't pick up all error codes so I should take it to the dealer but I'm gonna try your idea first and use it anyway. Does it work on iPhone as well?
Thanks again :-)
ID:	70426   Click image for larger version
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
User Tag List
DiscoMike
Linear Mode Linear Mode
D2 2001 21.000 miles flyboyaviator Discovery Series II 7 07-08-2010 07:38 PM
Major service, What fluids do i use??? akwagon Discovery Series II 5 03-02-2008 08:13 AM
95 ST For Sale $23,000 69k miles mlw911 Land Rover Vehicles 2 01-03-2008 06:42 AM
57,000 miles guitar588 Discovery Series II 13 10-26-2005 08:09 PM
In For Major Service AdrianL Range Rover Classic 10 01-26-2005 06:19 AM
You may post new threads
You may post replies
