mystery noise - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
  • 1 Post By redtruck12
post #1 of 10 (permalink) Old 03-31-2019, 06:58 AM Thread Starter
Quoted: 1 Post(s)
mystery noise
I have a noise driving me crazy.
MY 2003 Disc 2 HSE is making a squeaky whirling like noise when in motion.
not a grinding or metal sound
not a hissing sound
The noise begins after the first few miles from a cold start.
after that it is constant
It does not make the sound when the engine is idling or reeving
it starts from approx 10 mph and up
it does not appear to get louder based on speed
it is there in drive, 3, 2, 1 and in "N" when rolling
it appears to be coming from the front end?
based on me hanging my head out the window like a dog while a friend is driving
(yes, it has obsessed me)
i have removed all 4 tires and inspected for debris - no debris
brake pads are at 75%
calipers good
no brake burn smell
nothing wrapped on drive shafts
nothing on tires
brake shields not making contact
i greased all fittings
nothing appears loose
new belts
Any insight, ideas or suggestions would be great
Girouardrover is offline
post #2 of 10 (permalink) Old 03-31-2019, 01:41 PM
redtruck12's Avatar
Quoted: 281 Post(s)
Garage
Could be a few different things.
Possibly a wheel bearing starting to go bad?
Can you change the sound by cornering?
A bearing will sometimes change the sound it make with lateral load.
Twins Disco likes this.
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #3 of 10 (permalink) Old 04-01-2019, 12:45 PM Thread Starter
Quoted: 1 Post(s)
Redtruck12,
Thanks for the suggestion.
I will try this after work today.
I have never replaced the wheel bearings in the time that I have owned the rig.
(10 years 129K miles)
Would you suggest?
and what would you/anyone suggest would be a good type?
post #4 of 10 (permalink) Old 04-02-2019, 10:53 AM Thread Starter
Quoted: 1 Post(s)
UPDATE
the noise does not change when cornering.
It still begins after the first several miles from a cold start
and form 10 mph and up
very frustrating
post #5 of 10 (permalink) Old 04-03-2019, 02:03 AM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 9 Post(s)
Does the sound change when you swerve left and right while driving in a straight line like warming up your tires NASCAR style?
MIKE
- 2001 Discovery 2 SE (NAS LHD) “MYRTLE”, 110K miles, 4.0L V8, NGK Iridium IX plugs, PCV mod, 180* T-stat, Hayden fan clutch/Dorman fan, removed TBH, modded SAI filter, Safari Gard steel guards, Warn XD9000i winch, KO2 265/75R16 on steel rims, EBC rotors/Akebono pads, +2” TF lift & LEDs
- UltraGauge Blue, Foxwell NT510, Nanocom D2 V8 & TD5
JUKE179r is offline
post #6 of 10 (permalink) Old 04-03-2019, 03:33 AM
sierrafery's Avatar
Quoted: 246 Post(s)
did you check the oil level in the front diff and transfer case?
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is online now
post #7 of 10 (permalink) Old 04-03-2019, 04:55 PM
Quoted: 0 Post(s)
Probably front drive shaft u joints or Cardan inner centering ball. Rebuild them anyway if they are original
jetfiremuck is offline
post #8 of 10 (permalink) Old 04-03-2019, 06:50 PM
Quoted: 0 Post(s)
+1 Wheel bearings
Sounds a lot like wheel bearings..
SundayFunday is offline
post #9 of 10 (permalink) Old 04-13-2019, 05:49 PM Thread Starter
Quoted: 1 Post(s)
thanks for the suggestions
the noise doesn't change when swerving left or right while driving straight
the oil level in the front diff and transfer case is good
i have noticed that the noise seems to happen when coasting more than excelerating
i haven't had a chance to replace the wheel bearings.
any advice on what brand of bearings and where to get them?
post #10 of 10 (permalink) Old 04-13-2019, 06:21 PM
sierrafery's Avatar
Quoted: 246 Post(s)
I dont know where you can get them in your area but dont buy cheap chinese ones cos there are cases when they have 55 teeth instead 60 on the ABS reluctor ring then it mixes up the traction control without throwing a fault code and the vehicle becomes undriveable, this seems good enough for a decent price: https://www.amazon.com/dp/B0748MPMRX..._t1_B074817FN2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
help with mystery engine noise jakked Discovery Series II 8 09-14-2011 04:43 PM
Mystery whistling noise - HELP! inganina Range Rover P38, Mk III and Range Rover Sport 5 09-10-2009 12:51 AM
Loud mystery whistle noise - help! inganina Range Rover P38, Mk III and Range Rover Sport 1 07-22-2009 07:02 AM
Mystery Noise Greg M Range Rover Classic 6 08-10-2007 09:45 AM
mystery noise HALLIDAY Discovery Series II 3 12-16-2005 02:01 AM
You may post new threads
You may post replies
