new member, new Rover :) - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 19 (permalink) Old 03-05-2010, 05:35 PM Thread Starter
RAYMAN985's Avatar
Quoted: 0 Post(s)
hey guys, my name is Ray, im 23, im from NE Ohio, i just purchased an 03 Land Rover Discovery SE last week after researching a lot on here. it has 70k miles, one owner. clean carfax.
doesnt have sunroofs to leak, doesnt have SLS to go bad. no coolant in the oil(yet, knock on wood :P) not one of the bad oil pump VIN series. replaced the 3 front u-joints and centering ball with naepco greasables from Advanced Auto the day after i bought it.
next week im changing the transfer case fluid and front and rear diffs.
in the spring , im having Trailhead 4x4(Land Rover shop, not a car dealer) near me change the trans fluid and possibly the trans filters too. im personally changing the valve cover gaskets, plugs and wires with magnacores. the two little coolant hoses on the TB need replaced, leaking a little bit. then changing the coolant at that same time as well. little bit at a time, but asap too.
well ill think of more info, and questions to ask you guys(after searching), just wanted to introduce myself. SO excited about the new purchase, i have always wanted one, and found a nice one. not one scratch on it, two tiny door-ding size dents in the hood right next to each other, non smoker.
few little things need fixed, rear left corner black plastic piece has 2 broken clips, so its loose, not scuffed or cracked at all, just needs 2 new clips. right side, rear door flare needs stuck back on with some thin 3m automotive tape. all the flares need sanded and re-dyed or painted, they are faded on top and are a little rough. i found a black plastic exterior automotive trim dye kit at Summit Racing. ill have to check that out. other than that, it needs nothing, drives like a dream. very excited about the whole thing
here are some pictures
after i got her home
RAYMAN985 is offline
post #2 of 19 (permalink) Old 03-05-2010, 05:50 PM
k-rover1's Avatar
Quoted: 0 Post(s)
Welcome! good looking truck
k-rover1 is offline
post #3 of 19 (permalink) Old 03-05-2010, 06:12 PM
In The Shit
redhammer082's Avatar
Quoted: 0 Post(s)
nIce ..very clean!! I bought an '03 back in December and love the whole safety factor about it plus its does pretty bitchen off road. So you got it from a dealer . Did they give you any kind of warranty?? Oh do the belt if it wasnt done or get ready to. very easy. And love that style rim u have. I just did the plugs and wires.. got the NGK plats.. and ordered the kingsbourne 8mm wires ...22 for plugs and 47 for the wires, not to shabby.. when you do the valve covers dont forget the gasket for the plenum... I need to get some pictures of mine up especialy since the windows got tinted today....good luck wit it!!
redhammer082 is offline
post #4 of 19 (permalink) Old 03-05-2010, 06:17 PM Thread Starter
RAYMAN985's Avatar
Quoted: 0 Post(s)
thank you for the quick replies!
so i put in the 5w30 Valvoline oil in there. i have been searching around here for what oil is prefered, and im seeing TONS of different opinions. mines an 03 with the 4.6. what do you guys recommend? im thinking the 5w40, But what brand? you guys run Rotella diesel oil in your gas engines?
should i change my oil tomorrow? or will the 5w30 valvoline be ok for 3k miles until my next oil change?
im really paranoid because i want to take care of this engine, and im just seeing tons of different weights and brands, ratings that i dont know what that stuff means. and seems everybody here could have a different engine, either the 4.0, or a TDI engine etc.
what do you guys think about doing the seafoam in the oil/gas tank/induction(where would i pull the vacuum from for the seafoam in the intake) for my next oil change?
thanks again!
post #5 of 19 (permalink) Old 03-05-2010, 06:24 PM
k-rover1's Avatar
Quoted: 0 Post(s)
I run 5-40 Rotella T synthetic during the winter and 15-40 during the summer, Judging by the snow on the ground in your pictures, I would go with 5-40 to help with cold wheather start up. Dont forget Premium fuel will keep your engine running cleaner.
k-rover1 is offline
post #6 of 19 (permalink) Old 03-05-2010, 06:31 PM Thread Starter
RAYMAN985's Avatar
Quoted: 0 Post(s)
i ran nothing but shell gasoline in my previous jeep, and have put 2 tanks of Shell 93 premium in this already.i use nothing but Shell unless there isnt one around in an emergency. and i also ran nothing but mobil1 filters/mobil1 regular synthetic oil(NOT the long interval/high milage ones)
so 6 quarts of rotella 5w40 diesel motor oil will be good for this motor?
is it just me, or do the dipsticks in these motors suck and are hard to read, oil streaks up the whole dipstick, even when you freshly wipe the dipstick each time?
post #7 of 19 (permalink) Old 03-05-2010, 06:32 PM
In The Shit
Quoted: 0 Post(s)
I used mobil 1 10-40 Im also in AZ and dont really have to worry about FREEZE!!
I was in the same boat as you....what to use and shit.. Oh and the sea foam I read some postings about it but I still dont even know what the hell it is...LOL
post #8 of 19 (permalink) Old 03-05-2010, 07:09 PM
DiscoDream2's Avatar
Quoted: 1 Post(s)
Clean Rover! I love that interior color combination.
Welcome to the family!
DiscoDream2 is offline
post #9 of 19 (permalink) Old 03-05-2010, 08:22 PM
Benji's Avatar
Quoted: 0 Post(s)
welcome, you might want to think about removing the fender flares all together, I did on mine and love the way it looks, this is the only pic that I have right now. Its easy enough to do, just get a plastic putty knife to loosen up the 3m tape and pull them off, rub off the tape that stays on and then use some goo-gone to get the rest.
ID:	24543   Click image for larger version
2001 Disco II w/ 2" Terrafirma lift
265/75 Destination M/T - sold
1989 Range Rover Classic - sold
2005 Discovery 3 HSE
Benji is offline
post #10 of 19 (permalink) Old 03-06-2010, 04:24 PM Thread Starter
RAYMAN985's Avatar
Quoted: 0 Post(s)
i put the mobil1 301 filter in today, with Rotella T 15w40 oil non-synthetic. MUCH better!! took some new pictures today too
post #11 of 19 (permalink) Old 03-06-2010, 04:26 PM
In The Shit
Quoted: 0 Post(s)
SWEET !!!! man I just got my windows tinted, gotta get some pictures of it up... Im liken the shots
post #12 of 19 (permalink) Old 03-06-2010, 04:38 PM Thread Starter
RAYMAN985's Avatar
Quoted: 0 Post(s)
thanks! im still learning to use the Nikon D60, im getting a little better. i need the OME lift and disconnects :P these dont "flex" very well in stock form, but still just GO where you want them to, they dont stop! flex is overrated anyways
post #13 of 19 (permalink) Old 03-07-2010, 05:12 AM Thread Starter
RAYMAN985's Avatar
Quoted: 0 Post(s)
here is a picture of my Liberty that i got rid of. im gonna miss it but i sure do love my LR, so its not a huge issue
post #14 of 19 (permalink) Old 03-07-2010, 09:58 AM
In The Shit
Quoted: 0 Post(s)
WOW I would have to say I never saw one done up like that.. thats way cool , original ! so you guys might be getting more snow out your way .. there is a huge storm front that just came in off the coast of Cali and Im in AZ and right now we are getting pounded with rain...
post #15 of 19 (permalink) Old 03-07-2010, 10:23 AM
In The Shit
Quoted: 0 Post(s)
Here we go Ray ....finally some pictures when I first got this and did a little off raod trip with the fam.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
New member/new rover owner intro gregg877 Discovery Series II 5 01-19-2010 03:24 PM
New member from MD, broken rover jlittle New Member Introductions 5 03-06-2009 09:23 AM
New member and my Range Rover Nvrsetl Show it off 5 11-18-2008 08:49 AM
Newest Member Of The Land Rover Community Street Wolf New Member Introductions 0 10-07-2008 12:27 PM
You may post new threads
You may post replies
