New power steering pump - Land Rover Forums : Land Rover and Range Rover Forum
 2Likes
  • 2 Post By strap302
post #1 of 5 (permalink) Old 08-09-2019, 06:31 PM Thread Starter
G4 Mike
strap302's Avatar
Quoted: 12 Post(s)
Garage
I put a new power steering pump on my 2004 disco today. I got a new Cardon Select from Rock Auto for $212 plus a new Gates belt for $20. It looked almost exactly like the one I pulled out that had a Dana label on it. It fit fine and worked during the test drive.
Before I did the job I of course consulted the Land Rover manual and watched the Atlantic British video with Doug showing the way. In both cases they remove the fan. I got the fan wrench but couldn't get the dang fan off. It looked like I could sneak the pump past the fan so I gave it a try. I also noticed my fan looks like a fan and doesn't have that perimeter ring around it like the one in the British Atlantic video.
I unbolted the lifting bracket from the aluminum bracket and was able to sneak it past the fan. I positioned the pump flange between the blades and rotated the top of the bracket towards the left side and it wiggled out.
SafariDave and JUKE179r like this.
strap302 is offline
post #2 of 5 (permalink) Old 08-09-2019, 10:18 PM
WLADiscoII99's Avatar
Quoted: 213 Post(s)
$212 ... brand new ? Seems like a good price.
If you took your disco to a Mechanic .. they'd tell you .. you can't use your own parts .. they must buy them .. book approved only. Then they would tell you the parts were new .. and then they'd put on a used junkyard part. And you'd pay $600 for the steering pump .. and $900 for the labor .. and if you don't like it .. there's the door ..
What kinda fan is that?
1999 LR DII Performance Package with various Mods
Valentine One
Passport 9500ix
6 x Anti-Theft Camera System
2 x Anti-Theft Tracking devices
Veil Laser Paint
Anti-Laser Police Laser Jammer (5 heads + Dragon Eye protection) + Parking Sensors
Police Scanner + Waze
Powerful Pro-tuned CB-Radio with Fire-Stik
Remote+Hardwired License Plate Concealer
Armormax Bullet Proof Glass
Armormax Caltrop Deployment System
Steel Undercarriage Guards (Steering, Diff axles, Gas tank)
Voyager Roof Rack+six Jerrycans and five stacked Rotopax
Maxxis Razr Offroad Tires+Lift+LED bar
Allisport UK Aluminum Radiator
Allisport UK aluminum coolant tank with sight glass and coolant level sensor
WLADiscoII99 is offline
post #3 of 5 (permalink) Old 08-10-2019, 11:23 AM Thread Starter
G4 Mike
strap302's Avatar
Quoted: 12 Post(s)
Garage
Yes I think that was a good price for a brand new pump. O'Rielly's charges $336 for the exact same part. Atlantic British was about $380. All the forums I read said stay away from rebuilds.
The fan I think is the stock Land Rover fan that came on it I think. It has a Land Rover logo on one of the blades.
strap302 is offline
post #4 of 5 (permalink) Old 08-16-2019, 02:49 AM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 18 Post(s)
I've been looking for a mechanic to replace my V8 PAS pump. I keep getting quotes of £200+/$243+ to replace it even though I already have the pump and low pressure hose.
The British Atlantic video seems to make it look easy to do. I might have to go on and do it myself.
MIKE
- 2001 Discovery 2 SE (NAS LHD) “MYRTLE”, 110K miles, 4.0L V8, NGK Iridium IX plugs, PCV mod, 180* T-stat, Hayden fan clutch/Dorman fan, removed TBH, SAI modded K&N filter, Safari Gard steel guards, Warn XD9000i winch, KO2 265/75R16 on steel rims, EBC rotors/Akebono pads, +2” TF lift & LEDs
- UltraGauge Blue, Foxwell NT510, Nanocom D2 V8 & TD5
JUKE179r is offline
post #5 of 5 (permalink) Old 08-16-2019, 02:20 PM Thread Starter
G4 Mike
strap302's Avatar
Quoted: 12 Post(s)
Garage
If you have some mechanical ability it's not that bad a job, not counting the fan. I've since found out that there's a tool to hold the fan pulley while you use the 36 mm wrench on the fan nut. Give yourself 2 or 3 hours and take your time and it's not that bad of a job.
strap302 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
