no power to fuel pump, and inertia switch problem - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 62 (permalink) Old 10-01-2012, 09:20 AM Thread Starter
Quoted: 0 Post(s)
So thursday my disco died on me while driving, motor just stopped didnt buck or anything i didnt even notice until i pressed the gas down. i was going down hill and off the throttle. i still had all power to everything else. and everything else works just fine. i had it towed home and now have been trouble shooting all weekend. any advice would be gladly accepted.
cranks but wont fire
First i checked and replace the crank position sensor. (if i was going to pull it i thought i would just replace it)
spray started fluid and got it to fire up, to rule out a spark issue.
I have found that i am getting no power to the fuel pump, i have jumped power to the pump and it works. i have tested power through the fuse box, checked all relays and fuses, all good. i found a that in the plug wire to the inertia switch had been pinched and the white wire had some damage. I fixed the wire and got another another switch. the original switch didnt "pop" the switch though. so i thought it may have damaged the switch.
so im not really sure what to check. i dont have a wire diagram of the fuel pump set up and i dont know where the white wire goes to from the inertia switch. does it go to the ecu?
its a 2001 disco.
2003 DII
2001 DII
1997 P38 Vitesse -gone
kingstonman is offline
post #2 of 62 (permalink) Old 10-01-2012, 11:57 AM
Administrator
Quoted: 5 Post(s)
Possible fuel pump relay assuming you are getting a good signal from the crank sensor.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 62 (permalink) Old 10-01-2012, 12:41 PM Thread Starter
Quoted: 0 Post(s)
crank sensor is good. i have tested and swapped the relay and its good. I am just about to get home and test the white wire from the inertia switch to see if the wire shorted out (the one i found damaged). so far everything else has power and all fuses and relays are good.
one rover mechanic friend i spoke with is quick to say ecu problem. while i know it could possibly be an ecu issue i seriously doubt it. he is more of a throw parts at it and see if it fixes it type of guy. and thats not the right way.
2003 DII
2001 DII
post #4 of 62 (permalink) Old 10-01-2012, 01:36 PM
Administrator
Quoted: 5 Post(s)
How did you swap relays, there is only one that will work in a D2, none of the others will.
Need Parts?
Lucky8,
post #5 of 62 (permalink) Old 10-01-2012, 06:12 PM Thread Starter
Quoted: 0 Post(s)
i swapped the the started motor relay with the fuel pump relay, still cranked and wouldnt fire.
2003 DII
2001 DII
post #6 of 62 (permalink) Old 10-02-2012, 05:41 AM
Administrator
Quoted: 5 Post(s)
Check the number on both relays, I think you will find the fuel pump relay is different.
Need Parts?
Lucky8,
post #7 of 62 (permalink) Old 10-02-2012, 07:46 AM Thread Starter
Quoted: 0 Post(s)
would you, or anybody else know the part #? as i have switch my relays around and would not be sure which one was for the fuel pump anymore.
2003 DII
2001 DII
post #8 of 62 (permalink) Old 10-02-2012, 08:12 AM Thread Starter
Quoted: 0 Post(s)
i just ordered a fuel pump relay going to pick it up around 11, i will let you know the results.
2003 DII
2001 DII
post #9 of 62 (permalink) Old 10-02-2012, 08:44 AM
Administrator
Quoted: 5 Post(s)
Let me know how it turns out and if you would, send me the relay number so I can verify it.
Need Parts?
Lucky8,
post #10 of 62 (permalink) Old 10-02-2012, 11:30 AM Thread Starter
Quoted: 0 Post(s)
just replaced the fuel pump relay part #09214 1C from the top of the relay. still cranks and no start.
2003 DII
2001 DII
post #11 of 62 (permalink) Old 10-02-2012, 03:30 PM
LR Tech SD's Avatar
Quoted: 3 Post(s)
Can you hear the fuel pump prime for 5 sec after turning the key? Also check to see if you have spark.
Sent from my ADR6425LVW using AutoGuide App
LR Tech SD is offline
post #12 of 62 (permalink) Old 10-03-2012, 06:32 AM
Administrator
Quoted: 5 Post(s)
He has spark based on firing it up with some carb cleaner.
I am running out of ideas.
Need Parts?
Lucky8,
post #13 of 62 (permalink) Old 10-03-2012, 07:31 AM Thread Starter
Quoted: 0 Post(s)
im running out of ideas too, would the main relay effect the power to the pump?
LR Tech- i have spark, and no power to the fuel pump. the pump has been tested and works. i need to find what cause the motor to die and cut power to the fuel pump.
2003 DII
2001 DII
post #14 of 62 (permalink) Old 10-03-2012, 07:58 AM
Administrator
Quoted: 5 Post(s)
So, even if you prime the pump with the key, you get no 3 or 4 second pump run?
Send me your number and lets talk.
By the way., I am still thinking you may have the wrong relay. You mentioned you switch out a couple of your first, well there are 4 different large yellow relays from the factory, numbered RSL2 3 4 and 6 with only the RSL2 is an actual fuel pump relays, the others are not set to run the pump.
Need Parts?
Lucky8,
post #15 of 62 (permalink) Old 10-03-2012, 08:04 AM Thread Starter
Quoted: 0 Post(s)
the pump doesnt prime, there is no power to the pump at all. i have jumped power to the pump and it runs. i have also used a jumper wire to from the fuse box and got power to the pump.
i will pm you my number.
2003 DII
2001 DII
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Inertia Switch ducmed Discovery Series II 19 09-21-2011 07:39 PM
Bypassing the Inertia switch skippermccoy Range Rover Classic 2 12-17-2007 07:36 PM
1990 Inertia Switch MuddyRangeRover Land Rover Parts and Vehicles Wanted 1 10-29-2007 05:07 PM
92 V8i (Dual Fuel) - How to replace the fuel pump? AND an LPG problem... Please help! chrismillard Discovery Series I 3 05-01-2006 04:39 PM
Inertia Switch? Toddicus Discovery Series I 1 11-14-2004 08:56 AM
You may post new threads
You may post replies
