no power to fuel pump, and inertia switch problem - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
post #16 of 62 (permalink) Old 10-04-2012, 01:21 PM Thread Starter
Quoted: 0 Post(s)
checked and replaced the main relay, still nothing. does anybody have a link to the wiring diagram? i think my next step is to make sure the wires to the ecu are good?
2003 DII
2001 DII
1997 P38 Vitesse -gone
kingstonman is offline
post #17 of 62 (permalink) Old 10-04-2012, 01:33 PM
hafaday's Avatar
Quoted: 0 Post(s)
Go here.. bookmark it.. download all the stuff for the D2 and have fun.
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #18 of 62 (permalink) Old 10-04-2012, 01:40 PM Thread Starter
Quoted: 0 Post(s)
Thank you that is very helpful.
2003 DII
2001 DII
post #19 of 62 (permalink) Old 10-06-2012, 02:04 PM Thread Starter
Quoted: 0 Post(s)
so still no luck. i just spent most of the day going through everything with a buddy that is very skilled working with cars and we cant get it to start.
we went through all the wiring and everything was checking out. the one we were a little unsure about was on the fuel pump relay. we got 12v from (65) and 5v from (66) (see attachment. is that normal?
then we also tried to get the engine to run by jumping the fuel pump. so i can get the motor to fire with starter fluid, but can not get the motor to fire/run with the pump running. any ideas? because i am running out.
thanks
Name:	Snapshot 2012-10-06 14-58-26.jpg
2003 DII
2001 DII
post #20 of 62 (permalink) Old 10-11-2012, 07:02 AM Thread Starter
Quoted: 0 Post(s)
Well i still have not figured out the problem, i sort of put it on the back burner as i picked up an 03 black on black 4.6 HSE7 yesterday. i am in the process of transferring everything over to my new truck (rack, ladder, sliders, skid plates, diff guards, lift wheel/tires, stereo, etc...)
I am leaning towards the ecu as the injectors are not opening now either. as soon as im able to get everything swapped over im going to get my old disco down to the shop and taken care of so i can sell it.
I will update when i figure out what caused this problem.
2003 DII
2001 DII
post #21 of 62 (permalink) Old 10-11-2012, 11:37 AM
Administrator
Quoted: 5 Post(s)
I can't remember did you reset the inerita switch and or by pass it, if it is acting up, the pump won't activate.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #22 of 62 (permalink) Old 10-12-2012, 09:24 AM Thread Starter
Quoted: 0 Post(s)
i did test the inertia switch, it was not triggered. i replaced it just in case, and i did try to by pass it.
here is a pic of my new truck too! i have moved the rack and ladder so far, sliders are off the old and just need to be installed. my plan was to get the suspension swapped today, but its raining.... so hopefully it clears up long enough for me to get something done on my day off!
2003 DII
2001 DII
post #23 of 62 (permalink) Old 10-12-2012, 09:40 AM
Quoted: 0 Post(s)
The new one looks better anyway
2003 Disco II
Custom front bumper, 2" Lift, Goodyear MTR Kevlar's Factory Rims painted Black and more miles then it should have!
frankiels3 is offline
post #24 of 62 (permalink) Old 10-12-2012, 12:54 PM Thread Starter
Quoted: 0 Post(s)
thanks, i will update a pic when i get everything swapped over. the new truck has sls, so hopefully this weekend i will be able to grab some stock springs and swap suspension with my other disco, then the wheels/tires, skidplates, diff guards and all my stereo stuff.
2003 DII
2001 DII
post #25 of 62 (permalink) Old 01-02-2014, 12:24 PM
Quoted: 0 Post(s)
I am having the same problem with my 01 disco...how did you solve the problem with the fuel pump?
addeible is offline
post #26 of 62 (permalink) Old 01-02-2014, 12:31 PM
Administrator
Quoted: 5 Post(s)
If you want to add onto this link, at least post all the specifics as to your vehicle, mileage, last tune up, ever replaced the CPS and what have you checked so far?
Need Parts?
Lucky8,
post #27 of 62 (permalink) Old 11-25-2014, 10:35 PM
Quoted: 0 Post(s)
Ran into something that has to be related today.
2004 Disco, 179K miles (Wife's truck). Pretty well maintained.
Recent history leading up to today.
1. Original alternator went out about four months ago; I replaced it with a refurbished NAPA unit. All good until a week ago...
2. Wife was driving it last week and the disco just died on her. She was able to restart it and drive it straight to the local LR dealership. They said it would take them a week to get to it and they gave her a loaner. Yesterday, they diagnose the issue as a bad alternator. I told them I'd get a replacement from NAPA and install it myself. They sold us a new battery to get it back home. OK...
3. Got a new OEM alternator from NAPA and installed it this morning. New battery and alternator - GOOD!
4. Driving up to Tahoe this afternoon in stop and go traffic, I noticed hesitation when I stepped on the gas from a stop - I actually thought I may have had my foot on the brake and gas at the same time (big boots). A few minutes later, same thing, except this time I got a "Service Engine Soon" and flashing green "M" and "S" gear symbols and flashing "D" gear indicator next to odometer. Pull off the road, shut it down and pulled the key out of the ignition. I start her up a few moments later and all lights reset except for the SES one. All seems fine.
5. I stop in Auburn for dinner about an hour later. Parked on a medium incline (nose up) and let the disco sit for about an hour. After dinner, I try to start it and it will only crank - not fire. Plenty of juice, cranking well. Called AAA and started to Google the issue on my phone. Checked all battery and alternator connections - they looked good. Phone died - last resort = look at the manual. I came across the Inertia Fuel Shutoff Switch and figured I'd give it a shot. I pressed on the rubber switch button (reset?) and she fired right up. Ran fine for the next hour all the way to Tahoe. We'll see how she does in the morning.
No door lock or flasher actuation, just fuel shutoff.
Any thoughts?
Thanks!
Tony Luna is offline
post #28 of 62 (permalink) Old 11-26-2014, 08:50 AM
Quoted: 0 Post(s)
Fired right up this morning...
post #29 of 62 (permalink) Old 11-26-2014, 03:33 PM
Quoted: 0 Post(s)
The plot thickens...
post #30 of 62 (permalink) Old 11-26-2014, 04:01 PM
Quoted: 0 Post(s)
Same sequence of events today. At highway speed, a jolt/hesitation followed by flashing dash lights. This time I noticed I was stuck in 4th gear when I pulled off the road. Shut her down, pull the key out, restart, all good again.
Stop for about an hour, and she only cranks - will not fire. No problem, I think, just reset the Inertia Fuel Shutoff Switch like last night. Didn't work. I pull the plug to the switch and jump it with a paper clip. BOOM! Fired right up again. Cool! Bad switch, right?
About 5 minutes into the drive, another hesitation followed by a complete shutdown - WTF!!! I'm sure this is what happened to the wife a week ago (bad alternator - I think NOT). Shut her all down, she starts right up. What gives???
Gurus, I need some insight. Help!!!
Thanks!
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
User Tag List
Linear Mode Linear Mode
Inertia Switch ducmed Discovery Series II 19 09-21-2011 07:39 PM
Bypassing the Inertia switch skippermccoy Range Rover Classic 2 12-17-2007 07:36 PM
1990 Inertia Switch MuddyRangeRover Land Rover Parts and Vehicles Wanted 1 10-29-2007 05:07 PM
92 V8i (Dual Fuel) - How to replace the fuel pump? AND an LPG problem... Please help! chrismillard Discovery Series I 3 05-01-2006 04:39 PM
Inertia Switch? Toddicus Discovery Series I 1 11-14-2004 08:56 AM
You may post new threads
You may post replies
