Noisy Lifters - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 03-13-2015, 05:31 PM Thread Starter
Quoted: 0 Post(s)
Noisy Lifters
Good oil pressure but, lifters are noisy. Any suggestions before I replace them?
2000 Disco II 189,000 miles
cedward95758 is offline
post #2 of 2 (permalink) Old 03-17-2015, 04:36 AM
'03 Disco SE
Bosnian Discovery's Avatar
Quoted: 12 Post(s)
At your mileage both the camshaft and the lifters are probably well worn and need replacing. The noise likely comes from lifter/cam lobe wear that has pushed the preload out of spec which has led to the noise.
You'll need to replace BOTH the cam and the lifters since throwing new lifters on a used cam will shorten lead to accelerated wear of both components. However it's a pretty involved job to get to the cam with the block still in the truck so you may be better off switching to a heavier weight oil to help with the noise. It doesn't make sense to throw so much money and time at an engine that's considered very high mileage.
Bosnian Discovery is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
lifters killerpav Discovery 3 / LR3 0 11-03-2012 10:53 PM
lifters atancreti Discovery Series I 11 06-10-2011 05:15 PM
Lifters atancreti Discovery Series I 0 05-29-2011 07:03 PM
Lifters ? kevin1 Range Rover Classic 16 05-02-2009 05:02 PM
cam and lifters. mcnabj Range Rover P38, Mk III and Range Rover Sport 2 01-30-2007 05:02 PM
You may post new threads
You may post replies
