P0301, p0305, p1300 - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 08-06-2019, 07:07 AM Thread Starter
Quoted: 90 Post(s)
P0301, p0305, p1300
04 D2.
Misfire 1 and 5.
Any pro tips on starting diagnosis?
Thanks. Appreciate you, as always.
sobieski is offline
post #2 of 8 (permalink) Old 08-06-2019, 05:52 PM
G4 Mike
strap302's Avatar
Quoted: 12 Post(s)
Garage
Check your spark plug wires and boots. I had two boots crack and cause misfires. Also the spark plugs.
strap302 is offline
post #3 of 8 (permalink) Old 08-06-2019, 11:40 PM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 18 Post(s)
This!
you can swap plug wires with 2 & 6 to verify the misfire.
MIKE
- 2001 Discovery 2 SE (NAS LHD) “MYRTLE”, 110K miles, 4.0L V8, NGK Iridium IX plugs, PCV mod, 180* T-stat, Hayden fan clutch/Dorman fan, removed TBH, SAI modded K&N filter, Safari Gard steel guards, Warn XD9000i winch, KO2 265/75R16 on steel rims, EBC rotors/Akebono pads, +2” TF lift & LEDs
- UltraGauge Blue, Foxwell NT510, Nanocom D2 V8 & TD5
JUKE179r is offline
post #4 of 8 (permalink) Old 08-08-2019, 06:40 AM Thread Starter
Quoted: 90 Post(s)
Gotcha on the wires & plugs.
The oddity is: i cleared the codes the other day when i first posted this and they still haven’t come back and it’s been driven regularly.
Theory: gas cap is often (in the az heat) hard for the mrs. to get on completely (which i tightened down,too, when i posted this the other day) and routinely throws the gas cap evap code.
Could the misfire codes and gas cap evap be related?
sobieski is offline
post #5 of 8 (permalink) Old 08-08-2019, 11:36 PM
Expert Crate Digger
JUKE179r's Avatar
Quoted: 18 Post(s)
With these Land Rovers, anything is possible.
MIKE
JUKE179r is offline
post #6 of 8 (permalink) Old 08-09-2019, 05:11 AM Thread Starter
Quoted: 90 Post(s)
That is so true - how about probable in this case?
sobieski is offline
post #7 of 8 (permalink) Old 08-09-2019, 08:51 AM
DiscoBenny's Avatar
Quoted: 34 Post(s)
Garage
In my experience, that evap code is sometimes partnered with the misfire codes. Of which a scatterbomb replacing of correct O2 sensors, wires and plugs magically fixed those and other codes.
Usual suspects are wires and spark plugs however I had misfires associated with O2...these Discos
Also cannot rule out a coil pack that split.
Buttttt, not trying to be silly here, is your Frau throwing in the right gas? I had a similar misfire issue when I was messing around with lower octane gas (my other disco handled it no problem, this disco however is another story)
1999 Disco II
2000 Disco II (RIP Baby)
1990 Range Rover Classic (stored)
DiscoBenny is offline
post #8 of 8 (permalink) Old 08-11-2019, 05:50 AM Thread Starter
Quoted: 90 Post(s)
Well the code still hasn’t come back yet.
We’ll see...
And
Yes Fraulein is putting in the right gas - it’s a valid/good question to double check.
sobieski is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
