Programming Engine ECU, How Long? - Land Rover Forums : Land Rover and Range Rover Forum
 2Likes
  • 1 Post By sierrafery
  • 1 Post By masantschi
post #1 of 11 (permalink) Old 03-11-2009, 09:51 PM Thread Starter
Quoted: 0 Post(s)
So, I was told by land rover that programming my new ECU will take 1-2hrs. DiscoMike says it will take about 15min(brain dead and hung over, lol), and I have to say I strongly agree with him simply because you are flashing a vin# and security code to the EEPROM. I don't know about you guys, but I have built and tested about 10,000 electrical boards that do various things and it took only a few minutes to flash on the software. Most of that time was prep work. Why would they say it takes 1-2hrs, besides them being greedy.
The software I was flashing on was smaller then what the ECU contains, but I would be willing to bet the engine ECU carries no more then 5MB of space. I was working with 512KB chips.
I want to call the dealer on their bs, so I think I will request to come watch, I have been on the shop floor many times before, but I am sure they will give me some shit about how I cant be in there.
Have you ever had this done? How long did it take? How long do you think it takes?
CademiaX is offline
post #2 of 11 (permalink) Old 03-11-2009, 09:58 PM
mongosd2's Avatar
Quoted: 0 Post(s)
20 mintues (that includes the 15 minutes to swap them out)...most shops will charge the full hour...
01 D2 FZJ80 axles ARB/Detroit 37" Iroks, 14" 9100 Coilovers 14" 9100 rear 1.6 lt230 PSC hydro steering
1983 RHD Defender 110 Pick-up 200tdi/lt77
mongosd2 is offline
post #3 of 11 (permalink) Old 03-11-2009, 10:12 PM Thread Starter
Quoted: 0 Post(s)
well thats fine, but 2hrs..
CademiaX is offline
post #4 of 11 (permalink) Old 03-12-2009, 10:39 AM Thread Starter
Quoted: 0 Post(s)
Oh man, I am having way to much fun now!
I called the other dealer, there are 2 in the valley, they said they would install the new engine ecu, provided by me, and program it, said it would take about 30min, cost about $100.
Many calls to the other place, they said it is store policy that they cant install parts provided by me. They said it will take them 1-2hrs to ONLY program it.
VERY INTERESTING! Should have gone to the other one
and wouldnt you know, called a local shop that specializes in land rovers, the guy laughed at me when I said I needed a new ecm, he said he has seen them submerged in water, dried off and put back in and they work. He didn't know if he could program them, is that a dealer only thing? If he can he is going to make the effort and go to the dealer lot where its parked and program it.. LOL
CademiaX is offline
post #5 of 11 (permalink) Old 11-20-2012, 08:38 PM
mikebtvs's Avatar
Quoted: 0 Post(s)
follow up questions
CademiaX, what was the problem you were having with your disco causing you to replace the ECU? I've been having having problems with the car stalling, I've replaced everything I can think of outside of the ECU and I've had one place tell me that needs to be replaced. Where did you end up having it done? did it fix the problem?
mikebtvs is offline
post #6 of 11 (permalink) Old 11-20-2012, 08:41 PM
mikebtvs's Avatar
Quoted: 0 Post(s)
p.s. I'm in Salt lake too.
mikebtvs is offline
post #7 of 11 (permalink) Old 04-23-2017, 09:50 PM
Quoted: 0 Post(s)
I'm reading a lot on the land rover forum and maybe someone could give me some in put. I have an 03 freelander 2.5l that had a bad head gasket. Replaced head gasket set and head bolts doing proper tightening sequence. While having apart I replaced the fuel injectors and rail also replaced all coil packs and irridium spark plugs with land rover parts. As well replaced cam belts and timing belts and aligning using alignment tool kit to proper timing marks. Put back together and won't start or attempt to ...just cranks over. Have great spark and fuel pressure. Now it ran before replacing head gasket but smoked cloudy white. Also heads were done at machain shop. Does anyone know what could be issue of not starting...is this the ecm and needing to be programmed? Thanks everyone
Joseph Finkenbinder is offline
post #8 of 11 (permalink) Old 04-24-2017, 04:30 AM
Quoted: 531 Post(s)
Start a new thread in the appropriate model section.
And, no, it's not the ECU.
CT090 is offline
post #9 of 11 (permalink) Old 03-14-2019, 05:15 AM
Quoted: 1 Post(s)
Which software program can i use to reprogram a ECU?
sxmtech is offline
post #10 of 11 (permalink) Old 03-14-2019, 07:16 AM
sierrafery's Avatar
Quoted: 246 Post(s)
You can't use a ''software''... you need a dedicated Land Rover diagnostic tool unlocked for Discovery 2 to force the ECU to learn the immobiliser's security code from the BCU otherwise the engine will not run at all
JarmFam4 likes this.
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is online now
post #11 of 11 (permalink) Old 03-14-2019, 09:05 AM
Quoted: 59 Post(s)
If you plan to keep your truck, getting a diagnostic tool is of great value. I went with iLand myself and love it.
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 57 12-03-2010 12:33 AM
First post- LONG engine problem, but FUN! baghdadguy Discovery Series II 1 12-28-2008 12:26 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 02:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 06:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 03:46 PM
You may post new threads
You may post replies
