Rear brakes not working - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 03-22-2015, 07:50 AM Thread Starter
Quoted: 0 Post(s)
So my rear brakes are not working.. 99 d24.0... I'm at a loss.. Any ideas why this is happening?
bidman is offline
post #2 of 4 (permalink) Old 03-22-2015, 12:23 PM
helievacpilot's Avatar
Quoted: 35 Post(s)
And you know this how?
helievacpilot is offline
post #3 of 4 (permalink) Old 03-22-2015, 06:10 PM Thread Starter
Quoted: 0 Post(s)
Zero wear on rear rotors.. Rusting actually.. And i can feel the front brakes doing all the work.. Rears are cool to touch after driving when front are hot..
bidman is offline
post #4 of 4 (permalink) Old 03-23-2015, 05:48 AM
'03 Disco SE
Bosnian Discovery's Avatar
Quoted: 12 Post(s)
On a typical road car something like 60-80% of the braking force comes from the front brakes. So the fact that you say "I can feel the front brakes doing all the work" isn't necessarily an indication of a problem.
This bias prevents you from locking up the rear axle under braking as most of the weight shifts to the front. Therefore the rear brakes will wear a lot slower than the fronts and the rust may take a lot longer to rub off
That said, you may still have a problem if the rust doesn't go away completely.
1. Seized rear calipers.
It's not uncommon. Pull the rear calipers off and see if you can move the pins freely. If they're stuck you'll need to disassemble them, clean them up, and use quality brake (moly) lube.
2. Seized rear pistons.
Less common, but still plausible if the rust is bad enough.
3. Bad master cylinder.
Our MCs have 2 internal seals that create 2 internal chambers - one that creates the pressure for the front and one for the rear brakes. If there is an internal leak causing the pressure to bleed off it could lead to weak rear brakes.
4. Pinched brake lines.
Less likely, but worth checking.
Basically you need to inspect the rear brakes to make sure everything moves freely. Repair/replace/lubricate anything you don't like the look of - it's not rocket science.
Bosnian Discovery is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
brakes stop working randomly 67d100 Discovery Series II 3 12-07-2014 05:32 PM
Rear Brakes on '04 Disco redhawk Discovery Series II 2 06-20-2008 03:32 PM
No Rear Brakes skippermccoy Range Rover Classic 4 12-07-2007 01:21 PM
1997 Rear Brakes peaceoflight Discovery Series I 6 06-19-2007 08:41 AM
Groaning rear brakes Phat_pengiun Freelander / LR2 0 04-25-2007 12:33 PM
You may post new threads
You may post replies
