Rear Sunroof loose connector? Plus rear A/C - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 04-30-2019, 11:13 AM Thread Starter
Cheleto's Avatar
Quoted: 0 Post(s)
Hi Im new. Def gonna post more later.
Ive been having a 2003 disco II Se7 for half a year now, but the rear sunroof and rear ac don't work. Im working my way from the front to the back and I came across a plug with the yellow and green wires loose but not on both switches in the front. Should this be connect? It was wrapped in foam. But I cant see where it would go.
*It had a leak in the front sunroof the would let water in all infront of the headliner.*
Also any idea what should be replaced regarding these if the car has been sitting for 5+ years... I know lol. It still has the motor for the sunroof and rear ac blower. Maybe motor needs to be replaced come to think about it?
Everything works fine subwoofer and all speakers/ windows etc. Its just the rear ac and sunroof. Thank you.
Cheleto is offline
post #2 of 5 (permalink) Old 04-30-2019, 11:16 AM Thread Starter
Cheleto's Avatar
Quoted: 0 Post(s)
I guess I have to insert photo in code text? I pulled out the sunroof switches in front and theres the conectors loose behind it. Ive checked back switch and all is connected.
Cheleto is offline
post #3 of 5 (permalink) Old 04-30-2019, 12:58 PM
Bleeds Green
discovering's Avatar
Quoted: 25 Post(s)
Garage
Fairly frequently people will disconnect the switch for the back sunroof if the motor goes bad. Hook it up and give it a shot. If it still doesn't work, check the fuse. If the fuse is bad, replace it. If it still doesn't work (and maybe blows the fuse) you probably have a bad rear sunroof motor. Fixing it isn't too hard, but it does require lowering the headliner.
2014 Range Rover Sport HSE
2006 Range Rover Sport Supercharged
2004 Discovery SE7
2003 Discovery S7 (sold)
What do you call a Land Rover that doesn't leak? Empty.
discovering is offline
post #4 of 5 (permalink) Old 04-30-2019, 08:43 PM Thread Starter
Cheleto's Avatar
Quoted: 0 Post(s)
Ahh I'm believing its a bad motor now too. I've checked fuses under hood fl8 and the one under driver dash and they were good. Only thing is I don't know where to connect the loose connector. Its a round cylinder with holes and it doesn't connect to either of the switches.
Time to undo the front I guess..
On the upside. My headliner is a lil wonky so getting to the motor to see everything up there wasn't a problem. Hope its good lol Thanks.
Cheleto is offline
post #5 of 5 (permalink) Old 05-30-2019, 07:25 PM
very disco
reverendALC's Avatar
Quoted: 4 Post(s)
i realize this post is about a month dead, but for anybody who happens upon it..
i recently got my current 03SE7 a couple of months ago, PO informed me that the rear roof didn't work and did leak.
during my testing, i routed the motor leads from the front switch to the rear motor.
when powered from the front switch, the rear roof tried to open but failed while rising. i closed it fully, hit open again, and it made a little noise that sounded like mechanical energy being released, but it opened!
i then restored the electrical configuration and reconnected the rear roof to the rear switch, and it continued to work. i believe that the roof was jammed (or corroded) shut.
perhaps the wiring to the rear roof cannot sustain sufficient amperage to break loose? perhaps the leaking had corroded some of the electrical connections?
your mileage will definitely vary, but it's a SUPER simple test to perform and paid off big time for me
yep.
reverendALC is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Sunroof questionHello, I am aware of the several posts concerning sunroof operations, alexx Discovery Series II 0 08-02-2014 06:57 PM
Rear cluster connector p/n Discovery3driver Discovery Series II 0 06-08-2013 12:12 PM
Rear Air Spring Voss Connector Garo00 Discovery Series II 0 10-11-2012 07:00 AM
Non-sunroof headliner in sunroof RRC? yieldsign2 Range Rover Classic 7 09-02-2008 03:53 AM
Loose left rear quarter plug (by the airbag) Ioan Discovery Series II 0 11-18-2007 11:15 AM
You may post new threads
You may post replies
