Spark Plug Wire Problems - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 03-29-2015, 10:23 AM Thread Starter
Quoted: 1 Post(s)
I just recently replaced the plugs and wires in my 04 DII. I got the wires from the local land rover dealer. My problem is the cylinder 7 plug that goes on the bottom of the coil keeps coming off at the coil. When I try to push it back on it doesn't click in. All I can do is press it as securely as possible and move on. I've tried two different wires. Is there anything on the coil that can be causing this? I am just trying to avoid having to pull the coils out because I have a feeling that requires major amounts of parts removal.
DiscoFever88 is offline
post #2 of 3 (permalink) Old 03-29-2015, 04:17 PM
helievacpilot's Avatar
Quoted: 35 Post(s)
I remember being unable to get a lot of "push" on those lower coil connections. You might try a little dialectric grease on the inside of the boot as well.
If that doesn't work, I would get an inspection mirror and check out that coil connection and make sure it's not cracked or broken and is clear inside.
Oh Crikey! It's the Albanian Rozzers.
helievacpilot is offline
post #3 of 3 (permalink) Old 03-29-2015, 04:32 PM Thread Starter
Quoted: 1 Post(s)
Thanks. I will see what I can do visually with all the room down there lol I have a feeling I need to replace the coils anyways. it still has a small hiccup when its idling after new plugs and wires. Just double checking its possible to pull the coils without pulling the intake manifold? Ive looked it up but its always yes/no. Ill go off of my thread.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
2002 Disco II - spark plug and wire replacement kcShogun Discovery Series II 8 10-08-2010 11:44 AM
Spark Plug Wire Diagram 99DiscoMan Discovery Series I 1 10-03-2010 04:36 PM
Disco I Spark Plug Wire Set, New fourstrokin650 Land Rover Parts and Accessories 1 03-04-2010 02:23 AM
Broken Spark plug wire drice23 Discovery Series II 4 01-27-2009 04:03 AM
Spark plug wire install Portugal_Disco Discovery Series II 3 07-10-2006 08:58 AM
You may post new threads
You may post replies
