***DISCLAIMER***
I am not electrically inclined; however, I have a desire to learn and become such, so take it easy on me.
I am fairly certain I have a grounding issue on my DII Stereo. When I'm driving with the stereo on, I get feedback through all the speakers which gets louder (higher rpms) and softer (after shift/lower rpms). I've pulled my stereo out of the dash and checked the ground on the back, which is tight. I've searched the Rave to try and figure out the grounding points for the stereo/antenna, but I guess I'm just not seeing it because...I can't find it.
So my question: Is there a diagram which shows the grounding points for the stereo? ALSO - I'm going to be tearing down the engine soon and would like to make sure I have everything properly grounded when I put it back together so if there is a diagram with the grounding points for the engine, etc. I'll end up needing that too?
With my luck, I'm going down a rabbit hole but I need to start learning this stuff because I have a parasitic drain (which is not constant) I need to find as well.
