tackling stuff on the D2 and questions. - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 07-12-2019, 12:57 PM Thread Starter
member
SafariDave's Avatar
Quoted: 136 Post(s)
Going back to PR at the end of the month for a week and I am going to be tackling a few things on the D2 with a local mechanic that helps me with it.
1st is replacing the old water pump, it's started to leak when I left. I want to take care of it before it goes out and at the same time I will replace 2 hoses and deleting the throttle body heater coolant hoses.
I will also replace the fan clutch for a newer one I have.
Question On the water pump gasket. Can I spray tacky sticky stuff on both sides to the gasket or just the side that meets the engine?
What is the best type of scraper to remove the sealant left on the engine from the water pump gasket?
I will also replace the Drag Link and the track rod.
Dave
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my girl's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is online now
post #2 of 6 (permalink) Old 07-12-2019, 07:44 PM
LR Tech SD's Avatar
Quoted: 3 Post(s)
i normally just spray it on one side so it stays in place so you can get all the bolts in with out any issues
LR Tech SD is offline
post #3 of 6 (permalink) Old 07-13-2019, 12:46 AM
sierrafery's Avatar
Quoted: 246 Post(s)
IMO better not use any sealant if not needed, use a bit just on the pump's side as to keep the gasket in place untill you fit it to the engine, to clean the mating face i recommend this https://www.amazon.com/Permatex-8064.../dp/B0018PXX2I
from the WSM
Refit
1. Clean coolant pump and mating face.
2. Fit new gasket and coolant pump to cylinder
block. Fit bolts and tighten to 24 Nm (18 lbf.ft).
3. Connect feed hose to coolant pump and secure
with clip.
4. Ensure mating faces of coolant pump pulley
and flange are clean. Fit pulley and tighten
bolts to 22 Nm (16 lbf.ft).
5. Fit auxiliary drive belt.
+ CHARGING AND STARTING,
REPAIRS, Belt - auxiliary drive.
6. Refill cooling system.
+ COOLING SYSTEM - V8,
ADJUSTMENTS, Drain and refill
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #4 of 6 (permalink) Old 07-13-2019, 07:17 AM
DiscoBenny's Avatar
Quoted: 34 Post(s)
Garage
Had fun with this awhile back.
Used a block sander (foam thing with sandpaper all around) and that dramatically reduced my time cleaning old gasket.
Sprayed the tacky stuff on the gasket to attach to engine. THEN put water pump on with bolts.
No leak, no probs
Good luck!
1999 Disco II
2000 Disco II (RIP Baby)
1990 Range Rover Classic (stored)
DiscoBenny is offline
post #5 of 6 (permalink) Old 07-13-2019, 03:12 PM Thread Starter
member
SafariDave's Avatar
Quoted: 136 Post(s)
Thanks guys!
What size wrench do I need to remove the Fan Clutch?
Dave
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #6 of 6 (permalink) Old 07-13-2019, 05:35 PM
sierrafery's Avatar
Quoted: 246 Post(s)
It's 36mm but a normal wrench is too thick for that , you nedd a dedicated fan clutch wrench like e.g. https://www.ebay.com/itm/BMW-Mercede...-/123645361482
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
