Torque Converter Install - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 04-06-2015, 05:20 PM Thread Starter
prettynpink1029's Avatar
Quoted: 2 Post(s)
I am trying to install my torque converter and I have some questions. It is seemingly easy to get it on the double splined shaft other than it being heavy, am I missing something about it being hard to do?? I feel it is engaging on the second set of splines too. I spin it to the right and it goes no further. Is there more to it than this like with the inside tangs matching up to the slots on the rear of the torque converter? I'm so anxious to get my engine installed with the nice weather but don't want to be sorry. How can I be sure?
Thanks guys!
-Heather
prettynpink1029 is offline
post #2 of 5 (permalink) Old 04-06-2015, 08:11 PM
certified idiot
gurunutkins's Avatar
Quoted: 13 Post(s)
Should be 3 sets of locks, the stator, the turbine and the drive dog for the front pump. Its a feel thing - you should feel it lock in 3 times.
the best thing to do for a fitting check is to measure how much gap you have between the converter and the flex plate. As you dont wsnt to re-assemble - measure the amount the flex plate sticks out past the bolts hole face on the engine rear and measure the gap between the bolt pads on the converter and the bolt face of the bell housing. if the difference is not between 1/16 to 1/8 of an inch (or 1 to 3 mm) gap between the bolt pads on the convertor and the flex plate then it isnt seated far enough.
when its all bolted up you should be able to turn the converter and not touch the flex plate.
cheers
Barri
1999 discovery 11, some new cars, 1988 xj40, 1976 deville 8.2l, 1974 450sl, 1969 lotus 7, 1961 austin mini
the best view is always from the point of no return and you only ever have too much fuel when you are on fire.
gurunutkins is offline
post #3 of 5 (permalink) Old 04-07-2015, 06:04 AM Thread Starter
Quoted: 2 Post(s)
I am going to keep trying then and do the measurements, waiting on new engine mounts in the mail.
One more thing. I wanted to leave the truck in neutral so I can roll it in and out of the garage. Out of habit yesterday I put it in park and it is stuck in park (engine is out of truck). Is there a way to override and put it in neutral now? Tried connecting the battery terminals but no getting it out of P.
Thanks,
-Heather
post #4 of 5 (permalink) Old 04-07-2015, 10:12 AM Thread Starter
Quoted: 2 Post(s)
Hey Barri, I'm happy to say that I just got the TC in. I see a clear difference now. I put a little more pressure on it while spinning and I felt it link on.
As an fyi for anyone else doing this job...if the TC is moving in the shaft when you lift up on it a little then it is not in. As opposed to it being in the right depth/position when you lift up the entire tranny will move. Something you learn only from doing it. I dare say if you are guessing if its in then it's not in. Thanks again!!
post #5 of 5 (permalink) Old 04-08-2015, 03:19 AM
15mpg's Avatar
Quoted: 5 Post(s)
Congratulations on the torque converter replacement.
JK
15mpg is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Torque Converter Dereyk Range Rover Classic 0 11-05-2012 01:26 PM
Right torque converter? pilot13blackcat Range Rover Classic 1 10-16-2011 08:36 PM
setting torque converter empeluso Range Rover Classic 5 05-18-2010 09:53 PM
torque converter mrevo0 Range Rover Classic 2 12-23-2009 04:31 PM
HELP! Clanging noise! Torque Converter??? Paul 84 Range Rover Classic 1 09-10-2008 11:40 AM
You may post new threads
You may post replies
