Traction control not engaging when cross-axled - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 03-17-2015, 08:46 PM Thread Starter
Quoted: 1 Post(s)
On some significant terrain and my traction control didn't seem to engage.
No lights or other indication of a problem. Do occasionally have the 3 amigos.
2004 Disco II with the dif lock in low. Got cross-axled and the TC didn't engage so had wheel spin LF and RR. Seemed to work fine when on 30 deg incline of a stream bed of softball sized rock for a few 100 yards.
I was in 1st or 2nd gear.
'03 stock HSE and '04 modified SE. Suspension lift. ARB front winch bumper. WARN 8000. Safari full roof rack and snorkel. Terra rear bumper with recovery rings. Hella driving lights. Left, right and rear LED flood lights. Using TEKPro3000
massarst is offline
post #2 of 6 (permalink) Old 03-18-2015, 03:23 PM
helievacpilot's Avatar
Quoted: 35 Post(s)
Have you scanned for codes when you have the 3 amigos?
Oh Crikey! It's the Albanian Rozzers.
helievacpilot is offline
post #3 of 6 (permalink) Old 03-18-2015, 04:09 PM
certified idiot
gurunutkins's Avatar
Quoted: 13 Post(s)
Remember too that if the center dif is locked when you turn off the engine and you restart it with the center dif locked then it will automatically turn off the traction control.
If you want TC engaged then you have to NOT have the center dif locked when you stop and then restart the engine.
cheers
Barri
1999 discovery 11, some new cars, 1988 xj40, 1976 deville 8.2l, 1974 450sl, 1969 lotus 7, 1961 austin mini
the best view is always from the point of no return and you only ever have too much fuel when you are on fire.
gurunutkins is offline
post #4 of 6 (permalink) Old 03-19-2015, 04:50 AM
94svt50's Avatar
Quoted: 1 Post(s)
cheers
Barri
This does not apply to 03/04 models. They are programmed not to turn off traction control regardless of the start sequence.
'03 discovery HSE-7
'02 pathfinder
'89 yota 4x4
94svt50 is offline
post #5 of 6 (permalink) Old 03-19-2015, 05:25 AM
certified idiot
Quoted: 13 Post(s)
I know that is true for the 03 model that came without the mechanical part of the lockable center dif. If you had a way to disable the TC then it basically became a one wheel drive vehicle.
I was however under the impression that the 04 with the built in lockable dif feature did revert back to the same start up sequence as the earlier disco's.
I could well be wrong on that though I don't own one and the users manual doesn't say.
cheers
Barri
post #6 of 6 (permalink) Old 03-19-2015, 07:26 AM
Quoted: 35 Post(s)
cheers
Barri
The '04 does not require any "sequence" to keep everything working. I'm still leaning towards why he's getting the occasional 3 amigos.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
ABS/HDC(Hill Decent Control)/TC(Traction Control) lights on!! Michael Sparks Discovery Series II 3 12-29-2009 06:53 PM
Traction control? LebaneseShowoff Discovery Series II 11 07-29-2009 12:05 PM
TRACTION control Jupiter Rover Discovery Series II 20 10-15-2006 05:56 PM
Traction Control on D2 imag Discovery Series II 13 12-12-2005 06:15 AM
Traction Control jcobill Defender 1 12-05-2005 06:39 AM
You may post new threads
You may post replies
