Transmission Temperature Sensor - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 01-24-2012, 04:20 PM Thread Starter
SayeedAustin's Avatar
Quoted: 0 Post(s)
My 2001 Disco II Tranny temp light has been on even in cold. I figured it does not hurt to change the sensor as few suggested.
Question: Is this this right parts? Sender Oil Cooler Temperature Transmission | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
Is there other source someone can point me to ?
Thanks
SayeedAustin is offline
post #2 of 10 (permalink) Old 01-24-2012, 04:24 PM
Mr. t
MR.T's Avatar
Quoted: 0 Post(s)
Thanks
instead of guessing, find the sensor attached to the bottom of the tranny cooler and unplug it from it's harness while the light is on, if the light goes out then you know it's that particular sensor. that looks like the right sensor though.
\;/ complete rhino coat interior/MP3 converter(removed 6 disc)/Scan gauge II/2" RTE lift/terrafirma +2 shocks/terrafirma damper/RTE tie rod and drag link/tom woods front drive shaft/97 DI CDL/ K&N filter/RTE wide face front bumper/ SD roof rack and rear ladder/goodyear duratrac's 285/75/R16's/Brembo rear rotors and Will Tillery super secret brand front rotors/ Akebono Euro's all the way around/extended stainless brake lines/saudi spec grille/DI wipers/option "B" amigo free/ And Getting Badder Asser as the days go by\;/
MR.T is offline
post #3 of 10 (permalink) Old 01-24-2012, 07:10 PM Thread Starter
Quoted: 0 Post(s)
Someone mentioned both the sensors are connected in Series so the either one will trigger the warning, right? I am not sure though.
post #4 of 10 (permalink) Old 01-24-2012, 07:12 PM Thread Starter
Quoted: 0 Post(s)
Or we can short each of the connector to see which one is the broken one may be. Just a thought
post #5 of 10 (permalink) Old 01-24-2012, 07:35 PM
hafaday's Avatar
Quoted: 0 Post(s)
They tie together eventually. disconnect and see what happens.
Edit: the connector is to the right of the battery, rite at the radiator.
Name:	trans temp connector.jpg
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #6 of 10 (permalink) Old 01-24-2012, 07:44 PM Thread Starter
Quoted: 0 Post(s)
So the question is if I need the parts is this the right one?
Anyone else sell this parts?
Thanks
post #7 of 10 (permalink) Old 01-24-2012, 07:49 PM
hafaday's Avatar
Quoted: 0 Post(s)
Thanks
yes.. and check with PT. he's on here.
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #8 of 10 (permalink) Old 01-24-2012, 08:04 PM Thread Starter
Quoted: 0 Post(s)
Thanks. I have been trying to get the darn Rave installed but failed! I tried to unzip and put on a disk still no luck. any help?
I think PT was asking for $100 buck and AB's web says $69 not sure if they are the same.
Thanks
post #9 of 10 (permalink) Old 01-24-2012, 08:17 PM
hafaday's Avatar
Quoted: 0 Post(s)
Yeah, i had the same issue. then 1 day it worked. Go here an dl all for the D2. it's dam near the same as the Rave, except with out the accessories (add on's section).
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #10 of 10 (permalink) Old 01-24-2012, 08:36 PM Thread Starter
Quoted: 0 Post(s)
Thanks. Your picture you sent before it's a lot more clear though
Good night. Gotta get some sleep
Appreciated
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Help need to replae Transmission Temperature Sensor 2000 Disco II VRB Discovery Series II 17 03-10-2012 04:53 PM
Transmission Oil Temperature Light!! SayeedAustin Discovery Series II 13 01-11-2012 10:49 AM
Transmission temperature light.. on muddy-bugger Discovery Series II 13 07-11-2011 12:01 PM
Transmission Oil Temperature Threshold unstable Discovery Series II 24 06-12-2011 05:03 AM
air intake temperature sensor? ryanc8514 Range Rover Classic 1 04-11-2006 06:30 AM
You may post new threads
You may post replies
