Very Bad oil after the engine overhaul - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 13 (permalink) Old 01-29-2019, 09:13 PM Thread Starter
Sand fan!!
Quoted: 3 Post(s)
Hi, after I was having low compression in cylinders 8 & 6 I went for full engine rebuild... new: Rings, bearings, lifters, Sparks&wires, oil pump and high lift camshaft 53231.
I have the following issues since the first start till now ( ~ 1500 km):
- rough idle... The exhaust sounds crazy.
- oil turn to dark black very fast.
- high oil evaporation from pcv.
- multiple missfire on diagnostic.
- very high fuel consumption 30L/100km.
I have done a compression test for all cylinders and it was 150 psi +/- 5psi.
I've test the intake manifold for any leak by spilling some water.
Recently the back crank seal start to leak oil while I cancel the pcv and had an oil catch can.
I've tried to make the spark plugs with narrow Gap but no effect.
What you think I should do??
mshawari1 is offline
post #2 of 13 (permalink) Old 01-30-2019, 05:15 AM
tyl604's Avatar
Quoted: 178 Post(s)
What year and model?
tyl604 is offline
post #3 of 13 (permalink) Old 01-31-2019, 11:37 PM Thread Starter
Sand fan!!
Quoted: 3 Post(s)
2004 Discovery 4.6 NAS
post #4 of 13 (permalink) Old 02-01-2019, 06:36 AM
Quoted: 59 Post(s)
Who did the rebuild for you?
Just to make sure we understand fully, are you saying the truck was running fine, aside from the low compression in 6 & 8, prior to the rebuild and now it's doing all of the above?
Michael
'01 LR Disco II SE7
R.I.P. - 99 LR Disco Series II
For Used RRC Parts: Paul Grant [
For Used Disco Parts: Abran Abeyta [
For New Parts: British Parts of Utah or Atlantic British [most will price match Lucky8]
masantschi is offline
post #5 of 13 (permalink) Old 02-02-2019, 05:39 AM Thread Starter
Sand fan!!
Quoted: 3 Post(s)
The rebuild was done in-house with help of experience mechanical engineer. The rebuild kit from victor*REINZ expect one ring from britpart as we break it. Connection bearing was replaced. But other crank bearing was not changed since we didn't remove the block from*the car ... No honing ... Old pistons used.
No smoke comes from the exhaust so far ... I feel some pressure from crank ventilation over the valves cover
post #6 of 13 (permalink) Old 02-03-2019, 03:50 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 109 Post(s)
He wasn't that experienced.
There are so many things that could have gone wrong with your "rebuild" that I don't really know what advice to give. Good Luck
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #7 of 13 (permalink) Old 02-04-2019, 06:35 AM
Quoted: 59 Post(s)
I'm with ArmyRover on this one - there are so many things that could have gone wrong on your rebuild and if it was not acting like this beforehand, process of elimination says the rebuild either was done incorrectly OR reassembly was performed incorrectly. It sounds to me like you need to start tearing it apart from the top down to try and figure out where your problem is.
Sorry
Michael
'01 LR Disco II SE7
post #8 of 13 (permalink) Old 02-04-2019, 07:40 AM
tyl604's Avatar
Quoted: 178 Post(s)
Yes. I realize that is bad news but I agree. Something wrong with the rebuild.
tyl604 is offline
post #9 of 13 (permalink) Old 02-04-2019, 10:08 AM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
Seems to me it is inaccurate to call what was done a “rebuild”
Not even out of the truck??? I guess that’s why the mains were not done. It may have had some repairs but surely this cannot be considered a rebuild.
Back to square 1 on this one I’m afraid.
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #10 of 13 (permalink) Old 02-04-2019, 08:51 PM Thread Starter
Sand fan!!
Quoted: 3 Post(s)
Okay guys ... Guide me to the inspection steps. I would like to check if the cam alignment if it is correct. I'm planning to remove the valves cover and check if the cylinder no.1 valves are fully closed at TDC . Will but a screwdriver into plug hole to know if its at TDC. What you think?
Any other suggestions?
post #11 of 13 (permalink) Old 02-05-2019, 05:40 PM
ArmyRover's Avatar
Quoted: 109 Post(s)
My guess, due to the lack of honing the rings haven't seated properly. With the rings not working as planned you get blow bye. Blow bye will cause nasty looking oil, oil consumption and excessive crankcase pressure.
1972 MGB
post #12 of 13 (permalink) Old 02-09-2019, 08:09 PM Thread Starter
Sand fan!!
Quoted: 3 Post(s)
Update ...
There is small carnk case pressure.
I've visited two specialist:
The first one said it's due to slight miss alignment of the camshaft. But I can't see any indication of that.
Second one said it's due to wrong installation of ring with two cases .. a) flipped top ring, b) broken ring during the fitting.
What you think?
post #13 of 13 (permalink) Old 02-09-2019, 08:36 PM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
If it’s not apart it’s all just speculation.
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
AUX input is very very low sound volume cvtech Discovery 3 / LR3 11 12-15-2010 08:38 AM
Something very very wrong... PSM General Land Rover Discussion 2 02-01-2010 07:38 PM
Bad Amp...Bad Amp...Bad Amp... coldfrez Discovery Series II 2 05-20-2009 04:27 PM
Help my rover leaks like a sieve after overhaul owenslabounty Series Land Rovers 2 05-20-2009 03:34 PM
Hard Gear Shift After Transfer Case Overhaul royemaun Discovery Series I 2 08-20-2005 07:10 AM
You may post new threads
You may post replies
