What is the general consensus (if there is one) on what to use to clean the cylinder heads (already resurfaced) and the block before I replace the gasket?
I always use a good flat wide steel blade gasket scraper, carefully to not gouge anything and no abrasive sanding discs. Should feel smooth and then check with a good straightedge
If the heads are resurfaced they should not need anything more than a good wipe down
Related Threads
507.6K posts
71.4K members
Since 2004
