What is this and why is it leaking antifreeze? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 12 (permalink) Old 07-08-2019, 04:49 PM Thread Starter
Quoted: 0 Post(s)
02 Disco 2. I have antifreeze leaking from a small plate with 2 lines running into the bottom of the intake. There appears to be a gasket that has failed. Any help on what the replacement part needed would be great
antelope44 is offline
post #2 of 12 (permalink) Old 07-08-2019, 05:27 PM
very disco
reverendALC's Avatar
Quoted: 7 Post(s)
those route hot coolant through the intake to warm it up and prevent freezing. i think it's called a plenum?
that needed service on one of my past D2s, and was leaking coolant.
2003 Disco 2 SE7 - going to be buried in it
2006 RR Sport HSE - project
1997 Disco SE - SOLD
2003 Disco 2 SE7 - SOLD
1995 Disco SE - SOLD
2001 Disco 2 SE - SOLD
reverendALC is offline
post #3 of 12 (permalink) Old 07-09-2019, 08:02 AM
Redrover NC's Avatar
Quoted: 16 Post(s)
That's the throttle body heater, and a leaking TBH gasket is one of the most infamous and well-covered topics on this and other forums. Just do a search. It's poorly designed, which leads to it leaking repeatedly. Many DII owners simply pull the lines of the TBH nipples and plug them with small screws or bolts. Doing so has absolutely zero affect on the rest of the cooling system. That's what I did years ago.
In another thread British Parts of Utah posted that they have recently introduced a gasket made of silicone to try to overcome the poor design that causes conventional gaskets to leak repeatedly (linked below).
https://www.landroversonly.com/forum...le-body-93794/
'99 DII, STI wires, Champion 7070s, '04 CDL & SLABS, Garvin WILDERNESS rack, painted headliner, air springs victim, headgaskets at 109,000, plus victim of XYZ (twice) and many other ridiculous DII failures. Option B AMIGO FREE since February 2011.
Runs like a top; now if I could just afford the gas! December 2014 update - Wait, I can afford the gas! Drill baby, drill!!!
Redrover NC is offline
post #4 of 12 (permalink) Old 07-09-2019, 08:39 AM Thread Starter
Quoted: 0 Post(s)
Thanks, that honestly answers my question as I was just rationalizing why I couldn’t by-pass this. I’m going to plug them tonight. Is there any difference between plugging or just connecting them?
post #5 of 12 (permalink) Old 07-09-2019, 09:18 AM
Quoted: 16 Post(s)
Plugging is easier, in my opinion, and as I said doing so has absolutely zero affect on the rest of the cooling system. Those two small lines serve only the TBH.
post #6 of 12 (permalink) Old 07-09-2019, 10:25 AM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
I have eliminated it on my trucks with no noticeable difference, also seems to make bleeding the cooling system easier 😎rubber hose originally coolant tank to throttle and throttle to intake manifold (behind the alternator)
I just ran new hose intake to coolant tank/ reservoir.
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #7 of 12 (permalink) Old 07-09-2019, 10:40 AM
Quoted: 16 Post(s)
There's no harm in doing this, but no benefit either.
post #8 of 12 (permalink) Old 07-10-2019, 05:32 AM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
-1 less hose to leak
- 2 less connections to leak
- as well as no throttle heater to leak
- straight flow from intake to coolant tank so less places high in the system for air to get trapped.
Other than that “no benefits” 😉
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #9 of 12 (permalink) Old 07-10-2019, 06:12 AM
Quoted: 16 Post(s)
You missed my point. I meant that it's unnecessary to run a line from the intake to the reservoir when you bypass the TBH. I eliminated the line from the reservoir to TBH and plugged the line from the intake to the TBH.
post #10 of 12 (permalink) Old 07-10-2019, 04:21 PM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
Don’t think I missed your point.
So you have no small line from the engine to the resivoir?
If so I definitely disagree.
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #11 of 12 (permalink) Old 07-11-2019, 06:31 AM
Quoted: 16 Post(s)
No. There's no need. It's useless.
post #12 of 12 (permalink) Old 07-12-2019, 12:02 PM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
Next time you bleed the cooling system watch how much air travels out of that line= lots
Oh I guess you can’t. You eliminated it😉
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
