Will 33" BFG Tires fit a stock Disco II? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 26 (permalink) Old 10-01-2011, 06:12 PM Thread Starter
Dino the Land Rover
lehnebug's Avatar
Quoted: 0 Post(s)
Question Will 33" BFG Tires fit a stock Disco II?
Got a pretty good deal on some 33" tires but what all would have to be done to put on my stock 2000 disco II? Don't comment if you have something rude to say please. It's just a question. Thanks !
Lehne The Great
lehnebug is offline
post #2 of 26 (permalink) Old 10-01-2011, 06:16 PM
2003discoII's Avatar
Quoted: 1 Post(s)
for street use you can get away with some rubbing but i think they will rub to much off road when articulating
2003 disco. exhaust mod,265/65r18
2003discoII is offline
post #3 of 26 (permalink) Old 10-01-2011, 06:40 PM
cdeuso's Avatar
Quoted: 0 Post(s)
I'm going to say no. I tried to put 32" tires on my '03 with old worn out suspension. They didn't fit.
'03 Discovery- front driveshaft rebuilt, OME 751 & 762 w/ Terrafirma HD Shocks, ProComp 265/75 16 Mud Terrains, 4.11 HD gears, Rear Detroit, rear 1.5" spacers, F & R diff guards
'06 Mustang GT- the daily driver
cdeuso is offline
post #4 of 26 (permalink) Old 10-02-2011, 04:47 AM
Administrator
Quoted: 5 Post(s)
No chance in hell.
If you want big tires and are going off road, do a 2 to 2.5" lift and the tires will work and your truck will handle so much better.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #5 of 26 (permalink) Old 10-05-2011, 09:01 PM Thread Starter
Dino the Land Rover
lehnebug's Avatar
Quoted: 0 Post(s)
Originally Posted by Disco Mike View Post
No chance in hell.
Well, good thing were not in hell just kidding. Thanks for the advice I was just wondering...
Lehne The Great
lehnebug is offline
post #6 of 26 (permalink) Old 10-06-2011, 05:45 AM
Administrator
Quoted: 5 Post(s)
Why not throw a 3" lift on your truck and enjoys those tires?
Need Parts?
Lucky8,
post #7 of 26 (permalink) Old 10-06-2011, 07:05 AM
Quoted: 0 Post(s)
I'am considering the BFG KM2's just need to decide between these two.....
Any input would be greatly apriciated.
09130 LT285/70R18/E 127 Q RWL 7.5" - 9.5" 11.5" on 8.5" 33.7
31489 LT305/60R18/E 121 Q RWL 8.5" - 11" 12.2" on 9" 32.6
the 285's is a bit tall and the 305's is a bit wide.... but there is no 18" in between.
540is is offline
post #8 of 26 (permalink) Old 10-06-2011, 08:16 AM
Administrator
Quoted: 5 Post(s)
What are you going to be using it for and what other modification are you planning on to handle the bigger tire size?
Need Parts?
Lucky8,
post #9 of 26 (permalink) Old 10-06-2011, 10:01 AM
tbras104's Avatar
Quoted: 0 Post(s)
I run 265/65/18 tires with a 2" lift, and they fit well. Not sure if you can find that size in what you're looking at or not... I did have to add wheel spacers to keep from rubbing the radius arms. (could have adjusted the steer stops, but wanted the best turning radius I could get.)
Trenton
2004 Discovery II- 2" lift w/RTE HD springs and OME Nitro shocks, AT3 265/65/18, D1 rear spring seats, OME steering stabilizer, Slickrock Fab front sway bar disconnects, TW front driveshaft, rear diff guard, steering guard, extended steel brake lines, 25mm wheel spacers, OEM winch tray with VR10000 and Amsteel synthetic line, SD rack and 4 Ralley 3000 lights. STI wires and a bunch of new gaskets, 90k service done...
tbras104 is offline
post #10 of 26 (permalink) Old 11-30-2015, 06:07 AM
Quoted: 0 Post(s)
Toyo 33/12.5/18 Tires for Disco2
Does OME have a 2", 2.5" or 3" lift for the Disco2? I can only find 1.5". If not, any recommendations of other brands? With that said, do you think the Toyo 33/12.5/18 will fit?
I have the tires and rims already that was suppose to go on a Landcruiser that I sold. Trying to see if I can get them on the Disco and what it will take in size lift without cutting anything. If it is impossible or too costly, I'll have to just get new tires for the rims and go with the OME 1.5 or bigger lift. Need guidance please.
Regards,
Sean
Dark Horses is offline
post #11 of 26 (permalink) Old 11-30-2015, 07:55 AM
wjsj69
wjsj69's Avatar
Quoted: 11 Post(s)
I can't imagine toyota rims fitting but i guess you could make anything work with adapters or something. There are definitely bigger lifts; terrafirma for one, adding spacers another, but you have to replace radius arms and drive shafts as well as springs and shocks once you go above 2", or you'll have suspension geometry and clearance issues. You're also straining the drivetrain turning those big tires; should upgrade axle shafts or entire diff assy.'s. -Unless you're just mall crawling; then it doesn't really matter; just lift to suit and cut what you need to turn corners.
wjsj69 is offline
post #12 of 26 (permalink) Old 11-30-2015, 09:54 AM
Quoted: 0 Post(s)
Thank you. The rims are aftermarket XD Series. Hope they fit, will try them on later. Do you think those size Toyo tires would fit with a 2" lift?
post #13 of 26 (permalink) Old 11-30-2015, 11:55 AM
wjsj69
wjsj69's Avatar
Quoted: 11 Post(s)
I doubt it, but if you're willing to trim lots of plastic and sheet metal, maybe.. I think 30-31"s are about as big as i've heard people getting away with, without a lot of trimming and/or more lift.
wjsj69 is offline
post #14 of 26 (permalink) Old 11-30-2015, 02:02 PM
Quoted: 0 Post(s)
Thanks again. The rims won't work either. 6 lug as oppose to 5 lug on Disco. Well I guess I will stick with the stock 16" rims for now and get some Maxxis Bighorns for them. I live in Jamaica and my supply locally is very limited. Very good Maxxis dealer though. If I got the OME 1.5" lift with the stock rims, what's the largest tire you think I could get away with without doing any cutting and no rubbing?
Here are my choices:
Size Description Ply Rating Sidewall Overall Diameter (in) Section Width (in) Max PSI Max Load (lbs)Approved Rim Width (in)Tread Depth (in)
LT235/85R16 120/116N 10 BSW 31.7 9.6 80 3042 6.0-[6.5]-7.5 19/32
LT245/75R16 120/116N 10 OWL 30.6 9.8 80 3042 6.5-[7.0]-8.0 19/32
LT255/85R16 119/116N 8 BSW 33.3 10.3 65 3000 6.5-[7.0]-8.0 19/32
LT265/75R16 123/120M 10 OWL 31.8 10.6 80 3415 7.0-[7.5]-8.0 19/32
LT265/75R16 112/109Q 6 OWL 31.8 10.8 50 2469 7.0-[7.5]-8.0 19/32
LT265/75R16 119/116Q 8 OWL 31.8 10.8 65 3000 7.0-[7.5]-8.0 19/32
LT275/70R16 112/109Q 6 OWL 31.3 11.1 50 2469 7.0-[8.0]-8.5 19/32
LT285/75R16 122/119M 8 OWL 33 11.6 65 3305 7.5-[8.0]-9.0 19/32
LT305/70R16 118/115Q 8 OWL 33 12.4 50 2910 8.0-[9.0]-9.5 19/32
post #15 of 26 (permalink) Old 11-30-2015, 04:55 PM
redtruck12's Avatar
Quoted: 283 Post(s)
Garage
I run 275/65r18 cooper discoverer Sst mud tires on my 2000 with 2 1/2 lift. Supreme suspensions billet aluminum spacers, terrafirma plus 2 shocks. The only rub I have had was minor. Front and back of front tires on plastic stuff
I have since changed to a d1 bumper with a trimmed lower valence
Works very nice
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Stock '95 Disco Alloys with Newish Stock Size Tires DiscoSux Land Rover Parts and Accessories 0 11-17-2010 06:50 PM
will these fit a 2002 Disco II w/ stock 18" 2002DiscoII Wheels and Tires 2 02-03-2006 10:36 PM
Can 30" or 31" x 10.5" fit on stock Disco II? TsiArt Wheels and Tires 8 12-19-2005 04:18 AM
Largest Tires For 2003 Disco Stock 16" Wheels bernardmann Wheels and Tires 4 11-07-2005 04:28 PM
Trail wheels&tires! 16" Disco 1 wheels with BFG 265/70R16 M+S tires LRO-INTL Land Rover Parts and Accessories 0 12-30-2004 07:29 PM
You may post new threads
You may post replies
