06 LR3 keeps moving out of drive and into neutral - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 04-25-2013, 01:26 PM Thread Starter
Quoted: 0 Post(s)
We changed the shifter cable because it would pop out of drive and into neutral when you would drive. Now that only happens when you take a corner tight it will pop out of drive always. We adjusted it and the same thing happens. It's got a lot of play.
therabbit14 is offline
post #2 of 6 (permalink) Old 04-25-2013, 02:06 PM
Quoted: 1 Post(s)
Usually this is caused by the shift linkage at the transmission binding, which will cause tension, and even though drive is engaged, as soon as you get a bit of a torque shift, it'll drop into neutral.
The linkage can sometimes just be removed, cleaned, and lubed up, but often requires replacement as the plastic will get damaged during removal if it's real bad.
Dave
Land Rover Master Tech
Independent Land Rover Specialists
Chevy Chase, MD
RoverGuy7 is offline
post #3 of 6 (permalink) Old 04-25-2013, 04:48 PM
Quoted: 0 Post(s)
I second Roverguy7.
This is a typical example of gear linkage slipping.I cleaned and lubricated mine proactively long time a go and it is still fine, but replacement is fairly easy as well.
thorgal is offline
post #4 of 6 (permalink) Old 04-26-2013, 04:16 AM
Quoted: 3 Post(s)
I just had that issue few weeks ago, cleaned and oiled the linkage (i.e. sprayed WD40 and silicon lub, lol) and all is fine now, I even feel shifting the gear from P to D is much smoother.
But the real fix is described here:
DISCO3.CO.UK - View topic - Autobox Gear Lever pivot - How To
JeeZues is offline
post #5 of 6 (permalink) Old 02-27-2019, 05:41 AM
Quoted: 0 Post(s)
Would this be the same fix on an LR3 2008 Land Rover?
GOMAT is offline
post #6 of 6 (permalink) Old 02-28-2019, 10:28 PM
Quoted: 3 Post(s)
Yes
Globetrotter448 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Engine Always Stalls While Shifting from Neutral to Drive Only When Warmed Up DiscoV8'97 Discovery Series I 9 07-15-2013 08:23 PM
LR3 slipping out of drive fabrizr Discovery 3 / LR3 3 05-25-2012 05:22 AM
LR3 won't drive lexlaws Discovery 3 / LR3 28 02-01-2010 04:08 AM
Front Drive Shaft is Moving WLADiscoII99 Discovery Series II 16 12-15-2009 07:33 AM
Distributor drive blade not moving Sign Guy Range Rover Classic 0 03-23-2008 04:42 PM
You may post new threads
You may post replies
