2006 LR3 V8 EGR Valve Vacuum Leak - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
  • 1 Post By chadjones99
post #1 of 5 (permalink) Old 10-13-2014, 07:42 AM Thread Starter
Quoted: 0 Post(s)
As stated above, I have a 2006 LR3 V8 HSE with a vacuum leak. After a smoke test, I was able to pinpoint the area of the leak. Smoke comes out of the top of the EGR valve. I removed the valve and ensured it wasn't stuck open or closed.
Question, is the EGR valve supposed to let vacuum through it? I don't think so. Could there be a crack in it? Trying to get some insight before I spend $240 on the fix.
Bertmelchner is offline
post #2 of 5 (permalink) Old 10-13-2014, 05:01 PM Thread Starter
Quoted: 0 Post(s)
54 views and no thoughts? One of you must have done a smoke test to identify a vacuum leak. Did smoke come out of the erg valve between the electric solenoid on the erg valve and the part where the coolant runs through it?
post #3 of 5 (permalink) Old 04-07-2018, 02:21 PM
Quoted: 0 Post(s)
I'm having the same problem. Did you replace your EGR Valve?
Vest15 is offline
post #4 of 5 (permalink) Old 04-07-2019, 03:29 PM
Quoted: 0 Post(s)
EGR vacuum leak
I just did a smoke test and found 2 leaks I had the code for P0171 bank 1 lean , replaced front O2 sensor then cleaned back sensors , replaced spark plugs and coils , etc all of which it needed anyway it helped ,but I have a intermittent code for bank one and it will miss fire under the right load also . Sometimes runs perfect. anyway did a smoke test . 1 leak was easy around the bottom of the oil filler cap tube. Replaced O rings 2nd leak is around the EGR valve solenoid. I thinking of just doing a block off plate between the EGR and the solenoid . Has anyone been able to link this small vacuum leak to driveability issues ? and I see this post was April 2018 what was your outcome ?
chadjones99 is offline
post #5 of 5 (permalink) Old 04-09-2019, 03:55 PM
Quoted: 0 Post(s)
block off
update I just made a EGR block off plate and installed it, vacuum leak fixed !
SafariDave likes this.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Codes = vacuum leak? jbf Discovery Series II 6 09-29-2013 09:55 AM
do i need a vacuum delay valve? 90 red rover Range Rover Classic 1 08-30-2012 07:24 PM
Vacuum Valve Swarvey Range Rover Classic 0 09-17-2011 05:15 PM
Where is the EGR valve on 2001 4.6? Larry038 Range Rover P38, Mk III and Range Rover Sport 1 09-18-2009 06:52 AM
Vacuum Leak slangel Discovery Series II 3 01-23-2009 07:10 AM
You may post new threads
You may post replies
