Damn Brakes - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 05-29-2019, 03:29 PM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 12 Post(s)
Damn Brakes
Got a brake pad code, and I pulled the sensors, calipers, and pads. Cleaned where the sensors clip to brake pad. Checked pads and calipers and both were good and free moving. Put it back together and the pad light is still on!!!!!!!!!!!!!! Help!!!!!!!!!!
zilla is offline
post #2 of 9 (permalink) Old 05-29-2019, 06:48 PM
Quoted: 1 Post(s)
Garage
What vehicle?
bronzeking is offline
post #3 of 9 (permalink) Old 06-06-2019, 07:13 AM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 12 Post(s)
06 LR3 SE, 4.4 V8. The BRAKE light is on!
zilla is offline
post #4 of 9 (permalink) Old 06-06-2019, 09:50 AM
tyl604's Avatar
Quoted: 183 Post(s)
On my Mercedes you must push a reset button which is located on the master cylinder. Does the Land Rover have the same?
tyl604 is offline
post #5 of 9 (permalink) Old 06-06-2019, 11:43 AM
Duff
Quoted: 0 Post(s)
Zilla; you will find that once your brake pad ware sensor has tripped you will need a new one. You can cut the wires and connect them together and the light will go out. You can leave it like that or buy a new sensor and install it. Your local NAPA should be able to get you one or you can go to Atlantic British or probably most other auto parts stores for one.
howrdduff is offline
post #6 of 9 (permalink) Old 06-13-2019, 06:04 AM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 12 Post(s)
Thanks for the info on the sensors, I had just replaced the front, so I'm guessing the rear shorted out for some reason. Thanks, I'll try wiring the back in a loop bypassing the sensor. Still can't guess why it tripped.
zilla is offline
post #7 of 9 (permalink) Old 08-13-2019, 07:53 PM
Quoted: 1 Post(s)
Any luck?
Sent from my SM-G955U using Tapatalk
evileye4u2 is offline
post #8 of 9 (permalink) Old 08-14-2019, 10:18 AM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 12 Post(s)
Originally Posted by evileye4u2 View Post
Any luck?
Yep, changed the rear, no more light.
zilla is offline
post #9 of 9 (permalink) Old 08-14-2019, 10:26 AM
Quoted: 1 Post(s)
Thank you
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
