Help! Climate control issues LR3 - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 10-27-2018, 02:32 PM Thread Starter
Oaktown's Avatar
Quoted: 1 Post(s)
Hello, I have a 2006 LR3 HSE. The climate controls have a weird problem. With key on / engine off the controls work perfectly front and rear, everything responds and blend doors / temperature all work fine. Once you start the vehicle, the climate control turns on and is set to whatever it was set to when the key was on. The blower motor speed control, seat controls work normally but the temperature control and blend doors dont respond to the controls, the buttons light up but nothing changes. The only way I can force it change is by activating the heated windshield which will "shock" the system into working. I discovered the controls only respond under heavy electric load when the voltage dips below 13V. That's why they work when the heated windshield comes on. As soon as the voltage goes back up past 13V the controls stop responding again. I have changed the alternator and battery so I known it's not a charging issue, I have swapped the climate control module with a know working one and I have changed the relays as well. I am at a loss here. Any help is appreciated.
Oaktown is offline
post #2 of 8 (permalink) Old 10-27-2018, 04:48 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 109 Post(s)
That is wild.
umm yeah I have no idea on that one. Any HVAC codes in the ecu?
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #3 of 8 (permalink) Old 10-28-2018, 02:01 PM Thread Starter
Oaktown's Avatar
Quoted: 1 Post(s)
Originally Posted by ArmyRover View Post
That is wild.
None on my standard OBD2 reader. And no flashes when I do the manual check by pressing the recirculation and econ buttons. It just runs through the cycle and turns on again.
Oaktown is offline
post #4 of 8 (permalink) Old 11-03-2018, 05:43 PM
Quoted: 3 Post(s)
It is "NOT" set to driver preference like, seat mirrors etc
Globetrotter448 is offline
post #5 of 8 (permalink) Old 11-06-2018, 01:50 PM Thread Starter
Oaktown's Avatar
Quoted: 1 Post(s)
I dont believe there are climate settings perk key or driver
Oaktown is offline
post #6 of 8 (permalink) Old 11-06-2018, 07:18 PM
ArmyRover's Avatar
Quoted: 109 Post(s)
generic OBD II won't give you any codes. Mine passes the self check but has 3 or 4 codes for issues with the HVAC. Works normally so I keep ignoring them.
1972 MGB
post #7 of 8 (permalink) Old 11-08-2018, 04:23 PM Thread Starter
Oaktown's Avatar
Quoted: 1 Post(s)
what is the most used tool for enthusiasts that can read modules.
Oaktown is offline
post #8 of 8 (permalink) Old 11-10-2018, 06:59 AM
ArmyRover's Avatar
Quoted: 109 Post(s)
I use the Gap IID tool very good tool and excellent customer support. Pricey though at about $500 used ones come up from time to time and can be transferred for a small fee
1972 MGB
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
97 HSE no radio/climate control blacked out? matz445 Range Rover P38, Mk III and Range Rover Sport 8 12-07-2006 12:53 PM
climate control ksk228 Range Rover P38, Mk III and Range Rover Sport 5 10-11-2006 07:21 AM
climate control scotth Discovery Series II 4 07-09-2005 04:36 AM
climate control light bulb replacement GentrysRover Discovery Series I 1 04-10-2005 10:35 AM
Climate control conversion, manual to automatic Macgyver General Land Rover Discussion 8 03-08-2005 05:44 PM
You may post new threads
You may post replies
