need HELP!!! Multiple faults-wont stay running - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 08-09-2019, 07:13 AM Thread Starter
Quoted: 0 Post(s)
I have 2005 Land Rover LR3 4 Li V8, had it for about a year now but have only been able to drive it for about the first four months. It was running fine one day and then the next day I get in and the engine cranks starts, but then immediately shuts off. The same time this happened I got the following faults on the dash.
HDC Fault
Transmission Fault
Parking brake fault
Special programs unavailable
amber brake light is on
the suspension is all the way lowered and it won't air back up, if and when I get the LR3 started the compressor will come on for about 30 seconds then shut off without raising the suspension.
I have an inexpensive OBDII reader that is programmed for a land rover and I am getting the following codes
U2023- transmission receiving a fault from an external node
U0102- Lost comms with transfer case control module
U0416- Invalid data received from vehicle dynamics module
B1D12- Volumetric alarm
U0421,U0402,U0100,U0401
and one that says the MAF is reading wrong.
I am able to clear the faults but as soon as I get it running all the same codes come back.
I have changed the battery, the brake switch, checked the brake lights all work fine, checked the wires under the carpet on both sides (seem fine), pulled the Transfer case control mod- it had some corrosion and a pin had broken off, I have addressed the corrosion and the broken pin. I HAVE NOT changed the MAF yet, however I did get a cleaning spray and used that with little success.
I am thinking about getting a Gap Tool BT reader, with the assumption that I can update and flash all the control modules and maybe get a more detailed description of the faults.
PLEASE ANYONE give me some advise or a way to move forward,
THOUGHTS on the GAP Tool BT and what I plan on using it for.
blpettis is offline
post #2 of 4 (permalink) Old 08-09-2019, 12:19 PM
WLADiscoII99's Avatar
Quoted: 213 Post(s)
IDK but would says it's a computer problem.
1999 LR DII Performance Package with various Mods
Valentine One
Passport 9500ix
6 x Anti-Theft Camera System
2 x Anti-Theft Tracking devices
Veil Laser Paint
Anti-Laser Police Laser Jammer (5 heads + Dragon Eye protection) + Parking Sensors
Police Scanner + Waze
Powerful Pro-tuned CB-Radio with Fire-Stik
Remote+Hardwired License Plate Concealer
Armormax Bullet Proof Glass
Armormax Caltrop Deployment System
Steel Undercarriage Guards (Steering, Diff axles, Gas tank)
Voyager Roof Rack+six Jerrycans and five stacked Rotopax
Maxxis Razr Offroad Tires+Lift+LED bar
Allisport UK Aluminum Radiator
Allisport UK aluminum coolant tank with sight glass and coolant level sensor
WLADiscoII99 is offline
post #3 of 4 (permalink) Old 08-13-2019, 08:42 PM
very disco
reverendALC's Avatar
Quoted: 11 Post(s)
it seems that often times a rapid onset of numerous computer errors is related to:
low voltage at battery (check when powered off, check when running at idle if possible). easy to replace
check brake lamps and brake pedal switch
if you decide to replace the battery, that's a GREAT time to pull the plugs and inspect the TCCM, it lives right behind the battery. it's kind of a chore to get to, but inspect the connectors for corrosion. also not uncommon for water ingress to foul that up. if you see corrosion, the ECU right behind it should also be checked.
i just bought an 06RRS which was sitting on stops, and randomly (not every time) was throwing all sorts of errors including HDC, EPB, ABS, ATC... and many similar codes.
i bought the nanocom EVO and have been happy with it
next, check for corrosion under the FL and FR kick panels and door sills.
i ended up replacing my ATC module (which is actually attached to the ATC buttons on the console, they are all one unit). it turns out it was a scrap yard part to begin with, and looks to have had a latte unloaded into it.
the EAS (air) system is funky and appears to deactivate itself when the ATC and VDC aren't working properly. which color is your suspension warning light, orange or red? does the message center give you any info about the air suspension, and do you have the 4x4 display?
2003 Disco 2 SE7 - going to be buried in it
2006 RR Sport HSE - project
1997 Disco SE - SOLD
2003 Disco 2 SE7 - SOLD
1995 Disco SE - SOLD
2001 Disco 2 SE - SOLD
Foxwell NT510, Nanocom EVO
reverendALC is offline
post #4 of 4 (permalink) Old 08-14-2019, 03:05 AM
member
SafariDave's Avatar
Quoted: 142 Post(s)
Low or dead battery. (check if alternator is charging the battery)
Brake Switch.
Dave
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my wife's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
