OBD II Code: P0695, Fan 3 Control Circuit Low - Land Rover Forums : Land Rover and Range Rover Forum
 13Likes
post #1 of 113 (permalink) Old 06-19-2017, 04:27 PM Thread Starter
NavyDude
Mike Germann's Avatar
Quoted: 9 Post(s)
This code just popped for me, and appears to be an engine fan code. It was 105* when it happened. I immediately pulled over and shut the truck down. I could tell something was different because the truck sounded different - like the fan was much louder. It's pretty hard to describe noises, but wasn't the typical quietness from the engine. It reminded me of the kind of airflow sound that larger semi truck engines have when taking off. I also noted that as soon as I shut off the AC system, the engine sound went to normal and the temp stabilized. Truck drove fine after that but the code still remains. Can someone here help me connect the dots to what may be going on and how these things effect each other?
Also, I'm working with a newly installed radiator, coolant, and thermostat. Any input appreciated!
Mike G
2005 LR3 HSE
Bonatti Grey
4.4L V8
Tan Leather
202K+ on body, 80K on replaced 4.4L
Rhino 2.5" Lift Rods
TerraFirma 18" steel wheels
285/65/18 (32.6") RBP rubber
SYA Off-Road Bump Stop Extension Kit
Limiting Straps
TerraFirma rock sliders
Mike Germann is offline
post #2 of 113 (permalink) Old 06-19-2017, 04:48 PM
Quoted: 531 Post(s)
Sounds like maybe the aux fan going bad.
CT090 is offline
post #3 of 113 (permalink) Old 06-19-2017, 04:55 PM Thread Starter
NavyDude
Quoted: 9 Post(s)
This might be a silly question, but which one is the aux fan? During my radiator replacement I had half the front end disassembled and didn't see another one. I assumed "auxiliary" would suggest there's more than one fan. Is that correct? Or is it referring to the main fan? :shrug
Mike G
2005 LR3 HSE
Bonatti Grey
4.4L V8
Tan Leather
Limiting Straps
post #4 of 113 (permalink) Old 06-19-2017, 07:06 PM
Quoted: 531 Post(s)
The electric one
CT090 is offline
post #5 of 113 (permalink) Old 06-19-2017, 07:39 PM Thread Starter
NavyDude
Quoted: 9 Post(s)
Interesting. I don't think mine even has one. Wonder if it was previously removed, as I just purchased this about a month ago. Where should it be in relation to the engine fan?
Mike G
2005 LR3 HSE
Bonatti Grey
4.4L V8
Tan Leather
Limiting Straps
post #6 of 113 (permalink) Old 06-20-2017, 12:37 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Check fuse 10E in the engine bay junction box, if that's good the main engine elecro-viscous cooling fan is electronically supervised by the ECU so a problem with it will make the engine ECU log that fault code.... check if the connector(C2270 attached) is not loosen eventually try to stop the fan with a rolled up newspaper when the engine is hot... if you can you need a new one, or if it's not spinning fast check the relay too also verify resistance across the black wire in the plug and body to rule out a bad earth.... what ever it is the problem is in the fan's circuit(attached)
Name:	D3 cooling fan c2270.jpg
ID:	77569   Click image for larger version
Name:	D3 cooling fan circuit.jpg
Mike Germann likes this.
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #7 of 113 (permalink) Old 06-20-2017, 06:04 AM
Quoted: 531 Post(s)
I was thinking D2.
CT090 is offline
post #8 of 113 (permalink) Old 06-20-2017, 10:21 AM
morrisdl's Avatar
Quoted: 0 Post(s)
Garage
Is it an electric fan, or just an electric clutch with rotational power coming from the water pump? I think mine is going too. Good AB repair video on youtube on how to replace the fan (part of the replacing belts proceedure): https://youtu.be/1IghvL4sh4M?list=PL...Q9zGB3J5Esn-RY
Mods:
, 2" Lift Adj Height Arms,
morrisdl is offline
post #9 of 113 (permalink) Old 06-20-2017, 12:42 PM
sierrafery's Avatar
Quoted: 246 Post(s)
It's an electro-viscous complex unit controlled by the engine ECU with PWM signal
post #10 of 113 (permalink) Old 06-20-2017, 03:52 PM Thread Starter
NavyDude
Quoted: 9 Post(s)
Thanks for all the replies gents, much appreciated! I looked up the 10E but saw multiple forums that said the 10E was for suspension? Perhaps that was on other models? Either way, my fuses were all good. I also checked the fan connector, and the wires looked good. To be safe, I reseated the connector. As for the fan relay, I got my multimeter out but wasn't sure how to check the fan relay with the diagram provided on the component. I read that some auto relays should read INFINITE resistance, and others should read ZERO resistance. Wasn't sure which one this should be, but I got infinite resistance across them all.
The fan doesn't seem to spin very quickly, but once I turn the A/C on, it picks up speed. This may have been the air-y sound I was hearing before.
I recently had the fan out for a radiator replacement, but it's run for 300+ miles since then without issue, so I don't think it's a post-installation problem from that maintenance evolution.
On a side note, I also have a whiny pulley, so if I gotta take the fan off to test it I may as well replace the belt and that whiny pulley. Looks like it's coming from the idler but I'll try to grab a photo.
Mike G
2005 LR3 HSE
Bonatti Grey
4.4L V8
Tan Leather
Limiting Straps
post #11 of 113 (permalink) Old 06-20-2017, 04:30 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Originally Posted by Mike Germann View Post
... I read that some auto relays should read INFINITE resistance, and others should read ZERO resistance. Wasn't sure which one this should be, but I got infinite resistance across them all.
That's not good, no relay should have infinite resistance on the coil cos it's a solenoid... across terminals 85 -86 you should have resistance usually around 80 Ohm but it can vary depending on the relay's type just that it can't be open circuit cos then the relay is fubar
post #12 of 113 (permalink) Old 06-20-2017, 05:59 PM Thread Starter
NavyDude
Quoted: 9 Post(s)
Sounds like that relay troubleshooting may have narrowed it down. I'm not sure if I measured pins 85-86, I didn't see where they were labeled. Wouldn't I need to apply a test voltage to the relay to check its function, to see if it clicks? Just curious, I've worked with them before on planes but am unfamiliar with working on them in vehicles.
Hypothetically though, if that relay were bad, what would be the indication? Would the fan not work at all? Or would it not kick on during increased temps? It's kicking on when the car is at idle and A/C on. The RPM's just up a little bit when it happens and I can hear the fan spinning faster.
Is it possible this could be an intermittent shorting condition? It's 110* here in Central Valley, CA....I figure if there would be an overheating issue it would have just happened, I had the A/C cranked waiting at idle in the In-N-Out drive through line. Ran fine though.
Stumped.
Mike G
2005 LR3 HSE
Bonatti Grey
4.4L V8
Tan Leather
Limiting Straps
post #13 of 113 (permalink) Old 06-20-2017, 09:46 PM
sierrafery's Avatar
Quoted: 246 Post(s)
I don't know exactly how that fan operates cos the description is vague but as it's combined viscous-electric unit it might work on viscous coupling even without any feed... make sure that the relay is ok, if it's a normal 4 pin relay the coil is across the two parallel terminals but it should be a scheme on it's casing
post #14 of 113 (permalink) Old 06-21-2017, 04:51 AM
Quoted: 531 Post(s)
The fan can mechanically bind internally.
Imagine a fan clutch but instead of the bi-metallic spring telling it when to engage and disengage, it uses an electrical signal from the ECU. When they fail, they can not engage at all, or sometimes they can stick and stay engaged full-time.
They're using these on alot of the pickup trucks these days. They last alot longer, but they're expensive when they fail- don't know about the D3 on that, but I assume it's like all Rover parts.
CT090 is offline
post #15 of 113 (permalink) Old 06-22-2017, 07:22 PM Thread Starter
NavyDude
Quoted: 9 Post(s)
Good info, mate. any chance that would/could be an intermittent fault? Because it's not consistent, which is making it a PITA to troubleshoot.
Mike G
2005 LR3 HSE
Bonatti Grey
4.4L V8
Tan Leather
Limiting Straps
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Need fix for ERROR code p0579-Cruise Control Multi-Function Input "A" Circuit Range/P rocky1 Discovery 3 / LR3 6 04-12-2017 04:19 AM
Fan 3 Control Circuit? tjc Discovery 3 / LR3 2 12-03-2013 05:12 PM
OBD Error P0447? Vent Circuit Open audioclay Discovery Series II 4 08-22-2011 05:15 AM
OBD Code yellowlablounge Discovery Series I 2 04-14-2008 02:53 PM
Output Speed Sensor Circuit Fault Code cellulararrest Discovery Series II 7 08-15-2005 04:07 PM
You may post new threads
You may post replies
