Radio Volume...Water? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 05-09-2019, 10:01 AM Thread Starter
Quoted: 1 Post(s)
Long story short...
06 LR3 HSE. Radio volume works 20% of the time. Comes on randomly. When it's not working, it's almost like the radio doesn't even recognize the knob - it doesn't say "Audio Volume" or show any of the volume numbers like when it's working.
Pooling water in passenger footwell. I have replaced passenger sunroof drain, warped windshield cowl and blew out both AC drains. It's drying out slowly.
Question...could the water be affecting my intermittent volume issue or does that sound amp or software related?
06LR3HSE is offline
post #2 of 5 (permalink) Old 06-17-2019, 07:23 PM
Photoguy's Avatar
Quoted: 1 Post(s)
I'm surprised nobody replied, this is pretty common. I also have an 06, my experience is the water. I'll say 99% chance, yours is water as well. I know you replace the drain tubes, but they still periodically get clogged. Just need to poke down there with something, to clear out.
You could pour a little water down the sunroof drains (driver & pass), you'll know right away if it's clogged, should spill out somewhere in interior.
2006 LR3 V6 162,000 miles
Photoguy is offline
post #3 of 5 (permalink) Old 06-18-2019, 05:02 AM
tyl604's Avatar
Quoted: 180 Post(s)
Water may very well be your problem. My DII got wet at the front windshield and the radio stopped working; would not change channels and volume would play but not adjust up or down. It dried out and has been fine since.
tyl604 is offline
post #4 of 5 (permalink) Old 06-25-2019, 03:17 PM
Quoted: 0 Post(s)
any resolution to this? i'm having the same problem. head unit does not recognize volume knob- so no sound. happened when i tried to use the aux jack. didn't have any issue before doing that. ugh
errol is offline
post #5 of 5 (permalink) Old 06-27-2019, 07:25 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 109 Post(s)
There can also be water intrusion on the A Pillars due to leaks at the trim clip holes.
I cheated and drilled holes in the rockers to allow them to drain if there are leaks in the future
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
2005 Range Rover HSE Radio Volume pulses on and off rgrimes007 Range Rover P38, Mk III and Range Rover Sport 0 01-03-2013 12:43 PM
Radio help,no rear speaker volume!! morreale5 Discovery Series I 2 04-03-2012 06:18 PM
Inexplicable drop in radio volume Leaks Discovery Series I 7 09-17-2010 07:54 PM
Radio Volume is suddenly very low/quiet abqpatch Discovery Series I 2 03-21-2009 06:38 PM
Radio works, but can't turn up volume! (P38) troverman Range Rover P38, Mk III and Range Rover Sport 5 11-29-2005 05:27 AM
You may post new threads
You may post replies
