Receiver Hitch Key - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 19 (permalink) Old 03-23-2009, 11:41 AM Thread Starter
Quoted: 0 Post(s)
Receiver Hitch Key
My used LR3 came with the receiver hitch attached. There was no key furnished, the dealer tells me that I need to drop $80+/- for a new lock assembly as they can't sell me a key. Anyone have any suggestions? Thanks!
kevcam1030 is offline
post #2 of 19 (permalink) Old 03-23-2009, 12:12 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 109 Post(s)
Call a locksmith and see if they can make a key for it.
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #3 of 19 (permalink) Old 03-23-2009, 01:06 PM
drzjoint's Avatar
Quoted: 0 Post(s)
There is a way to get it off a guy on the disco 3 .uk site knows how
05 LR3 - 7 SE BLUE V8 aka
THE JUGGERNAUT BITCH"
drzjoint is offline
post #4 of 19 (permalink) Old 03-23-2009, 01:24 PM
drzjoint's Avatar
Quoted: 0 Post(s)
DISCO3.CO.UK - View topic - Lost my Removable Tow Bar keys
drzjoint is offline
post #5 of 19 (permalink) Old 03-23-2009, 08:54 PM Thread Starter
Quoted: 0 Post(s)
I tried the locksmith route, they said they didn't have a key to fit it. I don't know if this is some bizarre keyway or what exactly the problem is. I read the Disco3UK thread but couldn't find a solution other than PMing the moderator. I'm not sure how common a problem receiver theft is, but they make it sound like it's a Homeland Security issue. It sounds like I'd better get ready to cough up $80 for a new lock. Sigh.
post #6 of 19 (permalink) Old 03-24-2009, 03:17 AM
drzjoint's Avatar
Quoted: 0 Post(s)
Did you send him a PM? I belive it is relativly simple.
drzjoint is offline
post #7 of 19 (permalink) Old 04-10-2009, 11:00 AM
Quoted: 0 Post(s)
I have the same problem...
Baught my LR3 used and didn't have the Key. I told the sales person to contact the previous owner, but no luck. Guess it'll just stay on the car..
LR3_R1_R6 is offline
post #8 of 19 (permalink) Old 04-10-2009, 01:33 PM
drzjoint's Avatar
Quoted: 0 Post(s)
check you PM
drzjoint is offline
post #9 of 19 (permalink) Old 09-02-2010, 11:06 AM
Quoted: 0 Post(s)
Help!!!
I lost the key to my hitch on my LR3, I know I am new to the group but if this would help I run the forum site KayakFishingStuff.com: Closed for Maintenance. Runs on vBulletin as well but so does 70 percent of the others out there.
Jeff
2006 LR3 HSE
Hitting 100,000 Miles Woo Hoo
otecomputer is offline
post #10 of 19 (permalink) Old 09-07-2010, 08:16 AM
Quoted: 1 Post(s)
I had the same problem that you are running into. I did break down and buy the new lock mechanism, but it was closer to $50. I installed it myself. There is a way to remove the old handle by taking a small nail awl and driving out a pin that goes through the spindle that the handle turns. With that removed you can slide off the locking handle, and replace it with the new one, and then remove your hitch. I hope this helps.
mikkenspeed is offline
post #11 of 19 (permalink) Old 11-05-2010, 06:18 PM
Quoted: 0 Post(s)
had same problem i took a small screwdriver put it in the key hole moved it around on the key pins in top of key hole with a small forward rotational force. it is a very simple lock 2 or three pins to line up.
sherm27t is offline
post #12 of 19 (permalink) Old 01-18-2011, 08:01 PM
Site Sponsor
Quoted: 0 Post(s)
We have them available. check this:
Land Range Rover Sport LR3 LR4 Genuine Tow Hitch Receiver Lock Key
bpUtah is offline
post #13 of 19 (permalink) Old 01-19-2011, 02:08 PM
Rhinob's Avatar
Quoted: 0 Post(s)
Drill it out and buy the part above. This is how I did mine. My locksmith recommended I go this route as well.
Rhinob is offline
post #14 of 19 (permalink) Old 01-24-2011, 03:53 PM
Quoted: 0 Post(s)
I just purchased a 2008 LR3 HSE and was having the exact same issue. That picture that is posted above really helped me make it simple to remove without having the key. See that silver roll pin in the pic? Well that gets pushed into the green handle when mounted on the hitch...here's a hint, drive that pin out of your existing green handle with a 2.5mm allen wrench and a hammer. You'll figure it out from there. Scary how simple that was
BTW my local LR dealer only wants $22.50 for the handle and lock set.
perkj is offline
post #15 of 19 (permalink) Old 09-28-2011, 10:04 PM
Quoted: 0 Post(s)
Well, I had a similar issue happen in my hitch. I talked to locksmiths etc, all with no luck. I even asked the dealer if they could get it off. No avail. They told me they could drill it out for me, I declined obviously. So, I just drilled it out myself and it popped right off. Ridiculous.
vicjerry007 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Towing Hitch / Receiver Question Cali-Disco Discovery Series II 3 10-01-2007 10:26 PM
Receiver hitch capabilities natvboy Accessories 5 09-11-2007 02:25 PM
tow hitch receiver jenni Series Land Rovers 0 05-29-2007 02:23 PM
Mounting hardware for DII Hitch Receiver? afpilot Discovery Series II 1 07-15-2005 09:33 AM
WANTED: Disco II receiver hitch assembly O.B. Land Rover Parts and Vehicles Wanted 1 07-14-2005 01:58 PM
You may post new threads
You may post replies
