Transmission glitch - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
  • 1 Post By SafariDave
post #1 of 14 (permalink) Old 11-17-2018, 11:15 AM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 10 Post(s)
Transmission glitch
My tranny has intermittent shift issues. Mostly shifts ok, but sometimes it won't shift into 5th and 6th unless I manually shift it. Low fluid? Dirty filter?
zilla is offline
post #2 of 14 (permalink) Old 11-18-2018, 06:25 PM
Quoted: 3 Post(s)
Can be fluid, I would check the level, but it will not shift to high gears until engine warmed up
Globetrotter448 is offline
post #3 of 14 (permalink) Old 11-22-2018, 06:43 AM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 10 Post(s)
It did this even when weather was warm. I wasn't sure if fluid level could be the issue because it's not slipping? I will check the fluid level. Does it matter what type of fluid I put in since I don't know the previous maintenance?
zilla is offline
post #4 of 14 (permalink) Old 12-28-2018, 07:49 PM
Quoted: 0 Post(s)
Any updates?
Rhino007 is offline
post #5 of 14 (permalink) Old 12-29-2018, 02:32 AM
stanleychilambe's Avatar
Quoted: 0 Post(s)
Hello everyone. I have a disco 2. Just changed the flexplate but the car still won’t move. Any ideas please.
stanleychilambe is offline
post #6 of 14 (permalink) Old 12-29-2018, 08:07 AM
member
SafariDave's Avatar
Quoted: 133 Post(s)
How many miles on your LR3?
The Transmission fluid on an LR3 should be changed every 60 to 75K miles. I had mine done at about 85K with filter. at 111K plus miles now and its very smooth. Diffs and TC case every 25K
The City is a Jungle.
Present Land Rovers
1999 LR Disco II SD7 White 150K miles 'The Beach Boy' (PR truck)
2005 LR3/ D3 SE 4.4 Bonatti 'Fancy Professor' (my girl's LA LR3)
2005 LR3/ D3 SE 4.4 Bonatti 'The Rhino'
(my NYC LR3)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255/55/19
Past Land Rovers
1999 LR Disco II SD Niagara Grey 'Old Rhino' 200K+ miles (Sold)
1991 Range Rover Classic Green 'The Turtle' 200K+ miles (Sold)
1988 Range Rover Classic White 'The Rust Bucket' (Sold)
SafariDave is offline
post #7 of 14 (permalink) Old 12-29-2018, 08:12 AM
member
SafariDave's Avatar
Quoted: 133 Post(s)
Here is a kit:
https://www.roverparts.com/parts/ATFCKOMEWFL
Rhino007 likes this.
Present Land Rovers
(my NYC LR3)
Past Land Rovers
post #8 of 14 (permalink) Old 01-02-2019, 04:20 AM
Quoted: 0 Post(s)
My 08 LR3 is doing the exact thing...having a hard time shifting to 6th gear when tranny warms up. I can Sport shift all the way to 5th and have no issues driving until I try to shift into 6th and then car would "buck" and I'll end up trying to downshift manually and sometimes it refuses to get out of 6th gear. It will take me a few times slapping the shifter down gears. I took mine to my indy, so they said they'll look at it today. They said they're checking fluid level first.
Rhino007 is offline
post #9 of 14 (permalink) Old 01-03-2019, 06:46 AM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 10 Post(s)
170,000 when I got it , 177 now, changing all fluids next week. I read that steering angle sensor could have an effect on shifting?
zilla is offline
post #10 of 14 (permalink) Old 01-05-2019, 06:23 PM
Quoted: 0 Post(s)
Does it shift thru the gears manually if you use sport shift or command mode shifting? Mine will shift great all the way thru to 5th gear....just as long as I stay away from 6th.
Rhino007 is offline
post #11 of 14 (permalink) Old 01-06-2019, 07:19 AM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 10 Post(s)
Yes mine shifts fine through all gears manually, just 5 &6 are slow sometimes in auto. Hoping fluid change is the answer.
zilla is offline
post #12 of 14 (permalink) Old 01-08-2019, 12:49 AM
Quoted: 0 Post(s)
Well mine is in the shop...I may not find out what's wrong until Wednesday. I'll update you as soon as I know. Hopefully it something simple. Doubt it though. Lol
Rhino007 is offline
post #13 of 14 (permalink) Old 01-16-2019, 04:44 PM
Quoted: 0 Post(s)
Hey zilla...did the fluid change help? I'm getting the pan, filter and build changed. Plus the oil cooler hose replaced ( it was leaking). The dealer pulled the codes and said their TSB recommends replace transmission. So I took it somewhere else. Hopefully the dealer was wrong or just saying that since it may be easier to replace the tranny instead of troubleshooting deeper.
UPDATE:
Well the shop came back and stood it definately needs a new transmission... but their price is half of what the other place told me. $4800 installed... hopefully my LR3 will be back on the road by the end if next week!
Sent from my SM-N960U using Tapatalk
Rhino007 is offline
post #14 of 14 (permalink) Old 05-29-2019, 03:25 PM Thread Starter
Zilla 358
zilla's Avatar
Quoted: 10 Post(s)
No, fluids didn't change anything. I'm at a loss for thoughts on this.
zilla is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Discovery Transmission and Transfer Case 1996 Land Rover Discovery 4.0 Rangie Mark Land Rover Parts and Accessories 4 09-16-2011 09:31 PM
Moonroof glitch 91HunterRR Range Rover Classic 5 08-25-2009 04:28 AM
transmission problem duckslayer Range Rover Classic 7 10-31-2008 07:27 AM
Oil for S III transmission Craig Broadhurst Series Land Rovers 4 09-28-2004 05:11 AM
HELP! 02 Disco Transmission servicing Hurky67 Discovery Series II 8 09-10-2004 02:07 PM
You may post new threads
You may post replies
