2004 Disco II larger tire on stock suspension - Land Rover Forums : Land Rover and Range Rover Forum
 3Likes
post #1 of 18 (permalink) Old 01-11-2018, 07:18 AM Thread Starter
Quoted: 2 Post(s)
I've gone through a few threads as well as the Basic Tire Information sticky thread, but would like to hear more opinions or personal experience on putting larger tires on a 2004 Disco II with stock suspension. Ideally I'd like to not have to do any trimming (measurements according to tiresize.com):
Current/Stock:
255/55/18: 29.0" x 10.0"
Possible:
265/65/18: 31.6" x 10.4" (I've seen people say they have rubbing and some say they don't)
265/60/18: 30.5" x 10.4"
255/65/18: 31.1" x 10.0" (is there one that is 31.0" and a little wider that will fit?)
Thanks in advance!
elpaco313 is offline
post #2 of 18 (permalink) Old 01-14-2018, 03:06 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 109 Post(s)
I ran the 265/65-18 on my D2 and very little rubbing at full lock nothing that was worth worrying about. Truck looked great on them.
elpaco313 likes this.
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #3 of 18 (permalink) Old 01-30-2018, 09:46 AM Thread Starter
Quoted: 2 Post(s)
In case anyone comes across this thread; here's how this turned out:
I ended up getting the 265/60/18 (30.5" x 10.4") Goodyear*Wrangler DuraTrac. There is only a very slight rub on full lock to the right.
Here's what they look like:
post #4 of 18 (permalink) Old 02-05-2018, 01:18 PM
Lkstk's Avatar
Quoted: 3 Post(s)
Have you checked how far out the speedometer reads?
Harrison Sapir
103 Years of used car and truck parts
Lkstk is offline
post #5 of 18 (permalink) Old 02-05-2018, 02:37 PM
Drives like an old man
discomania04's Avatar
Quoted: 45 Post(s)
Garage
I think they look a lot better than stock, but Lkstk is right: your speedometer and odometer are now inaccurate. Might be a small trade-off because those tires sure fill the holes well!
2004 Disco II, bone stock, now weekends only
discomania04 is offline
post #6 of 18 (permalink) Old 02-05-2018, 05:49 PM Thread Starter
Quoted: 2 Post(s)
According to tiresize.com when the speedo says 60, it'll be going ~63mph. I do mostly city driving so it really doesn't matter.
post #7 of 18 (permalink) Old 02-05-2018, 07:17 PM
ArmyRover's Avatar
Quoted: 109 Post(s)
funny part is my D2 speedo was off when it was on stock tires, it read accurate with the bigger tires.
1972 MGB
post #8 of 18 (permalink) Old 02-06-2018, 08:57 AM
Lkstk's Avatar
Quoted: 3 Post(s)
Sounds close enough to not matter. Are you thinking about a lift? It looks good now, but two inches higher would be even more aggressive.
Harrison Sapir
Lkstk is offline
post #9 of 18 (permalink) Old 02-07-2018, 12:12 PM Thread Starter
Quoted: 2 Post(s)
Yeah, a 2" lift is something I would like, but have a few other things on my plate. So that will be down the road.
post #10 of 18 (permalink) Old 02-08-2018, 03:45 PM
Quoted: 32 Post(s)
IMHO a 2" lift would make the tires look less beefy. I like the stock suspension look much more. Lifts for appearance sake is like.....
2004 NAS Discovery SE - DD/Owner/Maintainer
number9 is offline
post #11 of 18 (permalink) Old 02-08-2018, 05:44 PM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
Talking
As for the lift...
I think that if most owners with what they consider to be "stock" suspension actually measure their actual ride height they will find that it is low at least 1 inch (spring, bushing and even body mount fatigue /wear).
I agree that doing a lift just for looks is just that - for looks.... But then I guess the same can be said for oversized tires.
Oversized tires and suspension lift will decrease fuel mileage, increase driveline stress, raise centre of gravity decrease braking efficiency
We can all argue to what extent but cannot deny the reality.
All that said.... I run 275/65r18 tires mainly because that is a common size with lots of options and a 2" lift that actually only works out to a little over an inch above stock height.
It looks COOL
sierrafery and Lkstk like this.
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #12 of 18 (permalink) Old 02-09-2018, 06:16 PM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
Elpaco313
Measure your ride height.
I would estimate from your photo that you are at least an inch low in the rear and probably close to 2" in the front.
Suspension upgrade (springs) buy good ones ... O.M.E. , Terrafirma etc. AND Shocks ( you will almost definitely find yours are worn out unless the have been replaced writhing a few years.
As a Goodyear retailer . Thank you for buying our products
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #13 of 18 (permalink) Old 02-12-2018, 09:51 AM
Quoted: 45 Post(s)
Garage
Hey, Red - What is the ride height supposed to be? And where would one measure it? If I'm sagging, it's time to spend a little money!
post #14 of 18 (permalink) Old 02-12-2018, 01:56 PM
redtruck12's Avatar
Quoted: 282 Post(s)
Garage
Hub centre to bottom edge of guard
...front 500mm +/- 15mm
...rear SLS 473mm +/- 15mm ...rear coils 485mm +/- 15mm.
Happy Happy Happy
2004 D2 se5 (sold)
1997 D1 (sold)
post #15 of 18 (permalink) Old 03-26-2018, 08:34 PM
WLADiscoII99's Avatar
Quoted: 210 Post(s)
You are going over all my past posts and anything with curse words you are issuing strikes. So if I am a cop and stop you for speeding .. I check camera database and issue tickets? That's baloney. If you want to kick me off this site because you're offended about my opinion of mechanics just abuse your authority and boot me. No need for a pretext. It's not like I've been a resigstered member on this website for almost TEN YEARS or anything ...
And I have a new story regarding the used tire put on my car ...
WLADiscoII99 is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > Wheels and Tires
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Please Recommend Larger Tire Size for Disco 5 W/O Lifting rsclark777 Land Rover Discovery 5 forum 39 05-14-2019 08:35 AM
tire fit stock 00 disco? flashpointdelta Discovery Series II 17 09-08-2011 01:13 PM
does a larger tire (285/60r18) fit on the spare tire carrier? lipadj46 Discovery Series II 2 02-09-2010 01:50 PM
FS: 2004 DII stock suspension parts, etc. grasshopper104 Land Rover Parts and Accessories 2 08-28-2009 07:57 PM
Disco II Spare Tire Mount (larger tire) xtreme90 Discovery Series II 0 12-12-2004 10:22 AM
You may post new threads
You may post replies
