Hi to everyone, I have a 2008 Land Rover LR2
Having a issue with phone , sound (radio, cd, rear sensor ) no working at all , got new battery change fuses etc no luck
Any ideas before take it to dealer ??
Diagnostic for $ 270
disconnecting things won't make it work... what did you disconnect?
the suggestion was to use a voltmeter to ensure that your +12VDC accessory leads are hot when the ignition is on.
if you had a code reader, you could check for faults on the stereo bus.
you can check in the driver and passenger front door sills for corrosion and damaged wires, water likes to get in there and corrode some of the sloppy splices.
another common issue is windshield leaks getting water into the stereo causing inoperability of the power button/volume knob
Related Threads
507.6K posts
71.3K members
Since 2004
