RRC abs - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 09-07-2018, 06:42 AM Thread Starter
Quoted: 0 Post(s)
RRC abs
Hello, I’m new on here and was wondering if I could pick your expert brains. I’ve got a 93 RRC lwb. I just replaced the abs pump. Upon ignition it pumped, built pressure and the brakes seemed to work. (Just test fitting, not held them yet) I turned it off. Upon trying again the pump would not come on. I depressurised via pedal pumping, thinking the pump would kick in. Nothing. Disconnected the pump, ran a feed direct. The pump kicked in. Checked for power at the pump (round plug). No power there. The relays click when ignition is turned. But pump fails to kick on. Where do I go from here? The vehicle has been sat for some time. A stuck valve in the abs block could cause this? It worked when first installed and test ran. But suddenly nothing. I hope you guys can point me in the right direction. I’d love to crack on with restoring the old girl. Many thanks in advance.
Sonnylad is offline
post #2 of 3 (permalink) Old 09-07-2018, 09:44 AM
tyl604's Avatar
Quoted: 178 Post(s)
Possibly a blown fuse?
tyl604 is offline
post #3 of 3 (permalink) Old 09-07-2018, 01:31 PM
sierrafery's Avatar
Quoted: 246 Post(s)
The fact that the relay clicks doesnt give you the certainty that it closes the contact too, if no power at the punp it's something wrong on that circuit, as @tyl604 suggested make sure that the main fuse MF6 is not blown and if it isn't check the feed on that path as in the diagram attached(no worries the '93's scheme is the same) put new relay to be 100% ruled out
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only Other > New Member Introductions
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
New ABS Diagnostic Tool - ABS Amigo Malafax_dand Discovery Series II 57 10-17-2014 09:32 AM
Looking to Borrow or Rent ABS Code Reader (aka RSW ABS Amigo) - Portland, OR mwyoung Discovery Series II 0 02-07-2011 04:19 PM
Converted Abs To Non Abs Now... njoerow Range Rover Classic 6 09-02-2010 08:42 AM
ABS issue (argh ABS is hard to search for) boon4376 Discovery Series I 4 08-13-2007 02:29 PM
ABS/ETC lights are off now ABS is over reacting Sign Guy Range Rover Classic 3 12-15-2006 04:27 PM
You may post new threads
You may post replies
