Clutch Won't Depress Series III - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 08-07-2010, 03:46 PM Thread Starter
Quoted: 0 Post(s)
I'm depressed, but my clutch isn't.
Driving home today in my sweet little lemon, the gears stopped catching smoothly as I shifted. The engine would race a little and then it would catch as I eased up on the gas pedal. Then I could tell I was starting to lose my grip as I could barely make it up a hill.
As I turned into my driveway the clutch would no longer depress. It's locked in the upright position, just like the flight attendant would want it, but that's not how I want it to be. I want it to depress so I can switch gears, which, in turn, will allow me to drive again.
I checked the clutch fluid reservoir and guess what? It was full, so that's not the problem.
Do I have a master and/or slave problem?
Tearfully,
Scott
tuxmiller is offline
post #2 of 9 (permalink) Old 08-07-2010, 05:05 PM
TerryS's Avatar
Quoted: 0 Post(s)
This portion of your description of the problem sounds like you're describing a sliping clutch. That could be that your friction plate is shot; your pressure plate isn't clamping sufficiently; or your hydraulics aren't allowing the throwout bearing to fully relax.
This part of your descriptions seems to be describing a pedal which can't be pushed down. Adding the two parts together is making me wonder if your problem might lie in the actual pedal box. The cross pin may have worked part way out, which was initially preventing the pedal from fully returning; hence the slipping (engine revving, barely able to make forward momentum).
If the pedal can not be pressed towards the floor, it seems more mechanical, and perhaps, now, the pedal cross pin is so coked as to prevent any pedal shaft motion.
Tearfully,
Scott
To positively eliminate the hydraulics as the possibel problem, crawl beneath the truck and crack the bleed screw on the slave. Depending on what year S3 you have, the bleed screw is in the end of the slave, or out at the end of some pipework (remote bleed screw) With the bleed screw open, have someone try depressing the clutch. If it now goes down, it may be a mechanical problem with the throwout arm, or release bearing.
Another possibility is that the check valve on the end of the master piston isn't releasing, because there is pressure in the line still with the pedal all the way up. A few operations of the pedal could have slowly pushed the slave to it's limit, and now the system is hydrolocked. This is probably due to a badly adjusted pedal piston rod.
TerryS is offline
post #3 of 9 (permalink) Old 08-08-2010, 05:13 AM Thread Starter
Quoted: 0 Post(s)
wow. thanks. what do I do if it's hydro-locked?
post #4 of 9 (permalink) Old 08-08-2010, 06:36 AM
TerryS's Avatar
Quoted: 0 Post(s)
If you let it sit overnight, by now it will have bled the pressure off thru the checkvalve. (If that's what the problem was) So, go see if you can push the pedal down now. If you can, it's probably not mechanical, i.e. pedal crosspin.
Don't sit there with a shit eating grin on your face, pumping away, and saying 'oh goody,, no more problem.' because you'll just hydrolock it again.
After you were successfully able to push the pedal down once, go get you green bible and adjust the pedal freeplay, and then you can go play.
TerryS is offline
post #5 of 9 (permalink) Old 08-09-2010, 11:38 AM Thread Starter
Quoted: 0 Post(s)
Nope, it's still in an upright and locked position. Can't even force it down. On to plan "B"...
post #6 of 9 (permalink) Old 08-09-2010, 08:17 PM
Quoted: 1 Post(s)
I had one lock up in the down position, the pushrod in the master cylinder had bent to a 90 degree angle. My foot was on the pedal at the time but I can't explain how it happened. Simply depressed the pedal and it wouldn't come up.
Greg S is offline
post #7 of 9 (permalink) Old 08-16-2010, 11:18 PM
jimrr
jimrr's Avatar
Quoted: 0 Post(s)
as i recall, series 3 hydrostatic clutch is not adjustable, the length of throw is predetermined.
hydro pressure on the clutch release seems most viable, if this can be eliminated, IE: ensure slave cylinder rod is indeed retracted, then you have a issue in the bell housing.
use some good hardware when you put it back together!
jimrr is offline
post #8 of 9 (permalink) Old 09-08-2010, 01:54 PM Thread Starter
Quoted: 0 Post(s)
What next?
OK, so I bled the clutch and here's what happened:
1). I was able to depress clutch to floor while bleed valve was open.
2). We cleared out all dirty clutch fluid and kept it topped off.
3). When I was able to depress the clutch, I was also able to shift gears as you normally would be able to.
4). When we close the valve each depression of the clutch would allow less downward motion. So it might be 3/4 first pump, then half and then stay at 1/4, not allowing you to depress any futher (kind of locking up).
5). As soon as we closed the valve and allowed the clutch pedal back up, we could never depress to the floor and shift gears again until we opened the bleed valve again.
Does this suggest a leak? Or if not that, then what?
post #9 of 9 (permalink) Old 09-08-2010, 02:54 PM
KevinNY's Avatar
Quoted: 0 Post(s)
Sounds like a new master cylinder is next. It's actually a very easy job if you remove the wing. I just did it last weekend.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Series Land Rovers
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Series IIa vs. Series III 330america Series Land Rovers 6 05-04-2010 07:14 AM
Broken clutch on my '66 Series 2a diesel? larrynsr Series Land Rovers 4 05-24-2009 06:51 PM
series 1 clutch jollyfatman Series Land Rovers 0 01-06-2007 06:15 PM
clutch 1965 series IIA captcory Series Land Rovers 3 05-14-2006 11:40 AM
Series 3 clutch g7jtk Series Land Rovers 2 10-23-2004 06:58 AM
You may post new threads
You may post replies
