4.2 Piston options - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 05-15-2018, 10:10 PM Thread Starter
Quoted: 1 Post(s)
4.2 Piston options
Hi all... I picked up a non-running 94 LWB dirt cheap a while back, and couldn't get it started. Turned out to be no compression on several cylinders.. I pulled one head, and its obvious I need some new pistons, at least one of them is chipped. I've yet to pull the other head.
Looking around, I don't see much in the way of 4.2 pistons for sale. Would 3.9 pistons work? Because they are taller, would they be too tall, or make my compression insanely high?
garionphx is offline
post #2 of 4 (permalink) Old 05-16-2018, 06:26 AM
p76rangie's Avatar
Quoted: 385 Post(s)
Firstly, if you pistons are damaged your bores are also likely to be damaged. If so, your engine is toast unless you want to put all new liners in it. This is because you cannot rebore these motors and they do not make oversize pistons for them.
I believe that the pistons between the 3.9 and 4.2 are similar. The 4.2 pistons are likely to have a larger dome in them to keep the compression ratio under control. I would think that you would be OK if you got 3.9 low compression pistons.
p76rangie is offline
post #3 of 4 (permalink) Old 05-16-2018, 10:10 AM Thread Starter
Quoted: 1 Post(s)
Yeah, I get that. A little background about the truck. I bought it after it sat in a (desert) field for 4 years. Engine would only turn about 10 degrees. Eventually freed the engine. For all I know, I damaged the pistons it when i freed it.
I plan on pulling the engine (have to get a hoist) sometime in the next few months, then I'll do more investigation.
post #4 of 4 (permalink) Old 07-05-2019, 10:34 PM
Quoted: 0 Post(s)
Garage
I have 8 good 4.2 pistons...
bronzeking is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Piston Slap rollrover Discovery Series I 7 02-02-2013 05:10 AM
Pitted Piston? origjcc Discovery Series II 11 10-17-2011 06:27 AM
Best way to clean piston tops ReNo111RoVeR Discovery Series II 6 02-01-2010 07:41 AM
Piston Problem sblindgren Discovery Series I 0 10-30-2009 09:05 PM
Piston Sleeve, displacement Mazmen1 New Member Introductions 1 10-04-2009 09:21 PM
You may post new threads
You may post replies
