90 RR Classic T case swap - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 04-30-2019, 04:36 AM Thread Starter
Quoted: 5 Post(s)
Will A pre 91 LT 230 be a direct fit
charlie2512 is offline
post #2 of 5 (permalink) Old 04-30-2019, 06:34 AM
p76rangie's Avatar
Quoted: 385 Post(s)
Yes.
Just double check that the prop shafts are the same length and whether the handbrakes are the same type.
p76rangie is offline
post #3 of 5 (permalink) Old 04-30-2019, 02:10 PM Thread Starter
Quoted: 5 Post(s)
any issues with transfer mounts or center diff lock linkage and lever install
post #4 of 5 (permalink) Old 04-30-2019, 04:06 PM
p76rangie's Avatar
Quoted: 385 Post(s)
I assume you have a viscous unit install at the moment. If so the linkage and lever have to be changed. But should be in same position
post #5 of 5 (permalink) Old 05-01-2019, 01:08 PM Thread Starter
Quoted: 5 Post(s)
yes I currently have a 90 classic with a rebuilt viscous coupling. I have located a very good condition LT 230 with linkage from a 91.
However does not have the side mount and will have to source that. This is all for a future swap if I have any issue with the V coupling.
I believe this early transfer may have a bit of gear noise compared to chain unit but will be bullet proof and I will not have to change transmission output shaft to mate up.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
t-case swap question and LT230 swap, why? rlmfire Range Rover Classic 9 03-08-2011 02:09 PM
90 RR Classic Power Steering / Alternator Q's LTRangeRover Range Rover Classic 5 03-10-2010 09:16 PM
My new '90 RR Classic County matthewk121 Range Rover Classic 20 08-15-2005 07:19 AM
89 ,90 RR classic , county parts used Reno Nevada SIDEYE Land Rover Parts and Accessories 1 06-08-2005 03:45 AM
was tilt steering wheel available on a 90 rr classic? ronrover Range Rover Classic 2 02-08-2005 09:14 AM
You may post new threads
You may post replies
