'93 LWB fuel pump relay keeps shutting "off"???? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 07-09-2018, 07:30 AM Thread Starter
'93 White LWB, 235/85R16, 2" OME, Bottorf bumper, T-Max winch
Quoted: 3 Post(s)
After replacing the fuel pump, filter, and relay in my ’93 LWB, I discovered that there was no power getting to the fuel pump. After checking the fuses and all circuits (inertia switch good, continuity from relay 87 post all the way to fuel pump-good), I discovered that the fuel pump relay itself was switching “off” after a few seconds being “on”. I removed the passenger seat so I could get a good look at it, and you can hear/feel it switch “on” when you turn the key on, but then it switches “off” after a few seconds.
I confirmed this with a circuit-tester; post 87 out of the relay sends power to the pump initially after key turns on, then relay clicks “off” along with power.
What can cause a relay to do this? I am beginning to suspect the ECU, which I think has a ground wire linked to this same relay.
brider is offline
post #2 of 3 (permalink) Old 07-10-2018, 12:08 AM
sierrafery's Avatar
Quoted: 246 Post(s)
Measure voltage on the perpendicular terminals(coil) of the relay when it switches off to make sure that the relay is OK cos it can have a "tired" coil and disengage despite of the feed it gets to it. If the feed is cut then it might be an ECU missbehaviour or a bad contact on the relay's coil circuit.
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 3 (permalink) Old 07-20-2018, 12:06 AM
p76rangie's Avatar
Quoted: 386 Post(s)
It is suppose to shut off after a few seconds. It will only run continuously if motor is running
p76rangie is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
"Vehicle fault system shutting down" error Dynamicv1 Range Rover Classic 3 11-27-2013 02:48 PM
'95 LWB Fuel Pump Issue, Which Relay is the FPR? E60RS Range Rover Classic 5 02-16-2012 11:42 AM
"clunk" sound from "P" to "R" and from "N" to "R" quietcoolone Discovery Series II 15 01-25-2011 01:57 PM
Disco 1 Fuel Pump + Fuel Pump Relay Toddicus Land Rover Parts and Accessories 1 10-11-2005 07:10 PM
Disco 1 Fuel Pump + Fuel Pump Relay Toddicus Land Rover Parts and Accessories 0 11-23-2004 11:42 PM
You may post new threads
You may post replies
