'93 LWB fuel pump removal, HELP! - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 06-11-2018, 10:33 AM Thread Starter
'93 White LWB, 235/85R16, 2" OME, Bottorf bumper, T-Max winch
Quoted: 3 Post(s)
I'm trying to replace the fuel pump in my '93 LWB, but the pump I got has fuel fittings that require a simple hose with clamps, and a standard-looking plug with pins.
My truck has threaded fuel lines and a plug that I can't figure out how to un-plug, looks like it should pull UP to un-plug?
Also, do I NEED the factory tool to un-screw the retainer, or can I carefully use a hammer and large screwdriver?
brider is offline
post #2 of 6 (permalink) Old 06-11-2018, 11:02 AM
Certified RRC Nut
pl626's Avatar
Quoted: 0 Post(s)
I used a piece of maple hard wood & a mallet. Worked perfectly and no damage to ring. I suppose a softwood like pine could work also. Just give it light wacks & it should be free to finish by hand.
Sent from my iPhone using Tapatalk
Cheers,
pc
'95 RRC SWB Alpine
'95 RRC LWB Avalon
'06 E350 Sport
'87 FLST with '02 Fatboy sheetmetal and wheels
'01 Hobie Getaway
pl626 is offline
post #3 of 6 (permalink) Old 06-11-2018, 11:10 AM Thread Starter
Quoted: 3 Post(s)
Thanks for that confirmation about the tool, now how about the fuel and elec connections? I'm wondering if I should try to get a different pump, but I'm tempted to cut the truck's threaded (and rusty) connections off, and use some barb connectors and new rubber line and hose clamps to insert the barb connectors into the remaining rubber line and just use this clamp connection.
Also, what about the elec connection? How do I get my current connector off?
brider is offline
post #4 of 6 (permalink) Old 06-11-2018, 11:17 AM
Certified RRC Nut
pl626's Avatar
Quoted: 0 Post(s)
On my Ď95, it was a bit of a wrestling match, but it eventually came off. Iím assuming your replacing the entire assembly, not just the pump? I bought an Allmakes assembly for less than $80 from Lucky8 after two Genuine assemblies failed in less than 3 months. Those were more than 3x the cost of the Allmakes.
Cheers,
pc
'95 RRC SWB Alpine
'95 RRC LWB Avalon
'06 E350 Sport
'01 Hobie Getaway
pl626 is offline
post #5 of 6 (permalink) Old 06-13-2018, 10:56 AM
mikieman's Avatar
Quoted: 5 Post(s)
Garage
On my 92 to remove the retainer I took a pair of vice grips and clamped them to the side and used a screw driver as a lever to Unscrew the retainer
im an american i dont speak english
1991 range rover
now parts
92 LSE
mikieman is offline
post #6 of 6 (permalink) Old 01-15-2019, 12:30 PM
hamrendan's Avatar
Quoted: 0 Post(s)
Pull the pump out of the new housing and put it in the old one.. you can use the old connectors and lines. use a few small flathead screw drivers to release the grips that hold it in..
Dan Hamren
95 LWB Beluga Black Chop Top With Roll Cage
93 LWB Ardennes Green ARB FT/ Rear
hamrendan is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Fuel Pump or no Fuel Pump, that is the question. Riker Range Rover Classic 5 11-15-2010 10:41 AM
93 lwb good parts truck for a 95 lwb michicks Range Rover Classic 4 05-08-2010 04:14 AM
'93 LWB County NA Distributor and/or IAM removal oddysseus Range Rover Classic 2 12-08-2008 02:33 PM
Disco 1 Fuel Pump + Fuel Pump Relay Toddicus Land Rover Parts and Accessories 1 10-11-2005 07:10 PM
Disco 1 Fuel Pump + Fuel Pump Relay Toddicus Land Rover Parts and Accessories 0 11-23-2004 11:42 PM
You may post new threads
You may post replies
