'94 doesn't want to shift into 4h - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 07-14-2008, 08:47 AM Thread Starter
Quoted: 0 Post(s)
My rover seems not to want to shift into 4wd. I haven't tried to force the stick, but it seems like it doesn't want to go forward. I've tried stopped, in "N" , rolling in "N" and so on, it doesn't seem to want to go no matter what I do. I got the truck from LA, CA back in December and haven't tried to put it in 4wd yet. I know, I know I should have done it. No telling how long it was before I got it (probably years). Otherwise, she seems happy. What gives? Can anyone point me to a existing thread? TIA.
1994 LWB County
"L'Nard"
Skidmarkart is offline
post #2 of 9 (permalink) Old 07-14-2008, 10:01 AM
XtremeMarine's Avatar
Quoted: 0 Post(s)
I am confused by how you wrote your post. Your truck is ALWAYS in 4 wheel drive. It's a Land Rover. If it's just a problem between 4H and 4L then I can understand the question; but it seems like you are under the impression that you are driving around in 2wd???
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
XtremeMarine is offline
post #3 of 9 (permalink) Old 07-14-2008, 11:33 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 111 Post(s)
Like XM said full time 4wd on these rigs.
Going on that I'll assume your stuck in 4 high and want to go into 4 low.
If it hasn't been used in a long time the linkage could be froze up get underneath and clean and lube the linkage. Then try again. Linkage is located on the passenger side of the Rover if memory serves.
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #4 of 9 (permalink) Old 07-15-2008, 08:24 AM Thread Starter
Quoted: 0 Post(s)
My apologies - years of 4wd'in has conditioned me to think in terms of 2wd -4h and 4l - you are right though, the little lever that goes between 4h (where it stays for normal driving) and 4l seems to be frozen. Like unwilling to move at all. I have followed the instructions in the manual, it just seems to be stuck in place. Do these rust or corrode? I don't want to force the movement.
1994 LWB County
"L'Nard"
post #5 of 9 (permalink) Old 07-15-2008, 08:33 AM
ArmyRover's Avatar
Quoted: 111 Post(s)
See above
1972 MGB
post #6 of 9 (permalink) Old 07-15-2008, 03:58 PM
94 Defender 90
cellulararrest's Avatar
Quoted: 0 Post(s)
Just don't kick it or anything. At least not too hard. I've broken two doing that...
cellulararrest is offline
post #7 of 9 (permalink) Old 07-16-2008, 05:51 AM Thread Starter
Quoted: 0 Post(s)
Thanks all. Will let you know how it works out.
1994 LWB County
"L'Nard"
post #8 of 9 (permalink) Old 07-16-2008, 05:58 AM
94 Defender 90
Quoted: 0 Post(s)
Another thought... Just realized that '93 and up has the solenoid lock so you can't shift without being in neutral... I'd give this a read:
Range Rover Remedies
post #9 of 9 (permalink) Old 07-16-2008, 06:08 AM
TerryS's Avatar
Quoted: 0 Post(s)
Electrical failure in the interlock circuit is very common, but not as common as the linkage being frozen from lack of use. DON'T force it, the top bracket, an aluminum casting, breaks very easily.
TerryS is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Shift Indicator Assembly... phyltered General Land Rover Discussion 1 10-17-2011 04:00 AM
manual shift and sport shift lights blinking? deepsessions Discovery Series II 1 08-15-2007 02:45 AM
manual shift and sport shift lights blinking? mnmike Discovery Series II 6 12-19-2006 06:38 AM
Gear Shift OSIYEZA Discovery Series II 3 12-14-2006 10:30 AM
First - Second Shift Problem OSIYEZA Discovery Series II 2 09-20-2006 02:04 AM
You may post new threads
You may post replies
