95 LWB RRC project - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 12-31-2012, 03:07 PM Thread Starter
Quoted: 0 Post(s)
95 LWB RRC project
Picked up this gem a few months back. I was so enamored I really didn't look it over too much- just plopped down my cash and went away happy. Well, after a while I started looking into why the 4x4 wasn't working and to my dismay I found no front driveshaft. Does already have a coil conversion.
The front diff pinion flange turns freely while the vehicle is on the ground and the front output flange on the tcase turns when the vehicle is moving. It's RWD at the moment. I've read and heard that this indicates a bad tcase, but I've also heard the opposite. In any case, there is something pretty wrong and I'm looking for advice on diagnosing it. Tcase is stuck in 4H.
Here's the plan:
Fix 4x4
Tune up
Patch radiator
Fix exhaust leak
Fix several small electrical gremlins
Slight lift
235/85/r16s on Disco steelies
Roof rack/bumpers/lights
Enjoy.
Some pics:
turboxr is offline
post #2 of 6 (permalink) Old 01-01-2013, 07:39 AM
Quoted: 0 Post(s)
There are numerous possibilities, but my first quests is that the viscous coupling (VC) in the transfer case (TC) is locked up. The VC can be replaced as an individual component in the TC, so you may not need to replace the entire TC. I suspect the locked VC caused a failure in one of the front CVs or the center pin in the differential. The only way to know what's happening in the front axle will be to open it up and see what's going on inside it.
Replacement VCs can be pricy if bought new, so you may want to look for used depending on your budget. I've heard that the VC for the RRC and the P38 are interchangeable, but you'll need to do the research to confirm if you wang to go that route.
Also I think D1 axle parts are interchangeable, but again you should confirm before purchasing.
76FJ55 is offline
post #3 of 6 (permalink) Old 01-01-2013, 10:19 AM
roverandom's Avatar
Quoted: 4 Post(s)
Nice Rangie!
A few quick searches on here should fill in the gaps of knowledge as to possible causes and repair options. As long as it's not rusty, they are worth fixing.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline
post #4 of 6 (permalink) Old 01-01-2013, 12:39 PM
Quoted: 0 Post(s)
Nice looking RRC. Lots of info. here on typical issues and how to solve them. If you can't / don't want to fix the Viscous unit, you could try putting an LT230 tcase from a D1 in there instead. I am looking for one for my classic at the moment.
2008 LR3 SE | 2008 RR Sport HSE LUX | 1989 RRC w/ 96 D1 motor, 2" OME, 245/75 BFG AT's, Warn 9.5ti, RTE front bumper and steering skid plate
Eniam17 is offline
post #5 of 6 (permalink) Old 01-01-2013, 02:23 PM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 112 Post(s)
Email Paul Grant he can supply you with a LT230 swap kit for your RRC at a good price. His email addy is in my signature
1972 MGB
2006 Bonatti Grey LR3 Proud Rhino Bumper, Baja Rack and TF underbody skid plates almost 33's lol
2007 Chawton White LR3 Proud Rhino lift rods
1983 Trident Green 110, TerraFirma suspension, and bumpers
1991 Range Rover Classic Hunter Eastnor Green
ArmyRover is offline
post #6 of 6 (permalink) Old 01-01-2013, 03:13 PM Thread Starter
Quoted: 0 Post(s)
Thanks so much for the responses guys. Yes, the RRC is nearly completely rust free. I do plan an LT230 swap. I've done a lot of research and searching on the forums, but I thought I'd ask if anyone had any other advice. Replacing the VC with an LT230 and going through the front axle assembly will be my first orders of business, perhaps after getting the radiator patched. Thanks guys! I'll keep updating.
turboxr is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
1989 RRC rebuild project rturbett Range Rover Classic 2 10-09-2012 07:08 PM
Just bought 94 LWB project dipstick Range Rover Classic 16 11-19-2010 07:20 PM
1990 RRC project tjrovertech Show it off 15 12-10-2007 10:08 AM
Project RRC Snorkel COmplete MuddyRangeRover Accessories 46 11-02-2006 07:32 AM
My new '88 RRC project Explorer4x4 Range Rover Classic 24 03-12-2006 02:37 PM
You may post new threads
You may post replies
