EAS light - random illumination; '94 SWB - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 4 (permalink) Old 06-04-2011, 07:00 PM Thread Starter
Quoted: 0 Post(s)
I hope someone might be able to assist me since I have performed much research/replaced many components in an attempt to diagnose the cause of the problem myself, however all efforts have failed to date.
The 'EAS' light (Wheel/wheel arch dash icon) illuminates at random (no CLEAR pattern) generally remaining on for about 20 seconds but sometimes only for a second or two - other times, perhaps up to 2 minutes. There have been occasions where I complete a round trip of 125 'Straight run' Highway miles (No light On) however the next day I may drive locally for a mere 10 miles (Suburban driving) whereby light will illuminate 3-4 times for varying 'short' durations.
The official L.R dealer (and a well experienced RRC/EAS experienced Independent) say that their L.R factory test equipment shows no fault 'code' (whatever) although I don't know what such equipment would show when the light is actually On, ie whilst mobile.
About 3 years ago I replaced all Air bags (Arnotts) and all had been OK until periodic 'light On' problem came 'Out of the Blue' ie no other works of any kind had been performed upon the car about that time.
The Dealer says one rear airbag is not seating 'perfectly' (?) and I've recently replaced (New) all four height control sensors which have been 'set' by the test pad/book and cross checked twice. I have swapped out the EAS Elec. 'Driver' unit and the silver EAS elec. control module (with known 'Good' units) neither of which made any difference.
Whenever the light illuminates I am not aware of any physical change in the aspect, attitude or height of the vehicle - just the damned light coming 'On' then 'off' is so irritating
As for overall EAS operation the system seems to work normally (Assumes 'Low' mode at highway speed etc.) however the switch on the dash to manually lower the vehicle does not do anything. Swapping the switch out made no difference, however I can live with that 'minor' (if unrelated?) problem.
I recently drove virtually 'straight' along a main highway with no light coming 'On', however when I entered some slightly hilly/twisty, 'tightish turn' mountain country it illuminated on/off with frequency.
Could it be that weight shift/balance/transfer of vehicle is affecting something perhaps?
L.R Dealer says rare instance of onset of Viscous coupling failure (or even Alternator) have caused EAS light to randomly flash 'On/off', however Independent L.R man assures me that both of those components are working properly.
I just dont know where to go from here. Could it be the simple relay under the seat? although I think I replaced that when I first bought my car thinking (perhaps incorrectly) that at that time the EAS compressor was running erratically, however I believe it is working and has worked normally with no undue noise etc.
Any advice would be deeply appreciated.
Thanks to all.
County 94 is offline
post #2 of 4 (permalink) Old 02-25-2018, 02:07 PM
Quoted: 0 Post(s)
Help Me
Hy,I'm writing from Italy.
Please, have you look for the cause of the EAS light s ON ?
I Have a RR 4.2 LSE with your Problem at the Light .
I have changed all the things, but nothing.
The light on Cockpit is always ON.
Please if you Can Help Me, write to my personal email:[email protected]
Thaks a lot,Andrea
il biet is offline
post #3 of 4 (permalink) Old 07-05-2019, 10:36 PM
Quoted: 0 Post(s)
Garage
push/seat the front abs sensors down with a block of wood and a mallet
bronzeking is offline
post #4 of 4 (permalink) Old 07-06-2019, 03:37 PM
ducsurfer's Avatar
Quoted: 1 Post(s)
Probably 85% of all RRC do that and 98% ignore it?
ducsurfer is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
automatic transmission selector illumination light fusti88 Discovery Series I 3 06-13-2010 07:40 AM
95 Swb Rrc Eas To Coil Suspension Conversion Question?opion Poll ROVERKRAZED Range Rover Classic 5 03-27-2008 08:01 AM
EAS - No Height Light Seanmc768 Range Rover P38, Mk III and Range Rover Sport 1 11-27-2007 01:09 PM
ABS, TC and Brake Light Illumination DevilDisco Discovery Series II 8 01-09-2006 07:52 PM
FS WA: 95 Classic SWB EAS Components Kristopher Land Rover Parts and Accessories 1 05-03-2005 08:13 PM
You may post new threads
You may post replies
