Gremlins - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 02-15-2019, 02:35 PM Thread Starter
Quoted: 1 Post(s)
Gremlins
I have a strange electrical situation with my 1989 Rangie and I'm hoping someone here may have had a similar issue, although it's seeming rather bizarre to me.
The headlights work, but the tail and park lights have stopped working, strangely, so have the rear fog lights.
There is power at the switch, 12.54V distributed as it should be by moving the switch to each selection, but there is only 0.6V at the fuses and bupkis at the sockets.*
The reading at the fuses does not appear to be an aberration, because both read the same value and that reading drops to zero when ignition is switched off.*
The rear fogs have full power at the switch and the fuse, but again nothing at the sockets.
I would be grateful for any constructive suggestions or advice.
Gaznazdiak is offline
post #2 of 5 (permalink) Old 02-15-2019, 08:20 PM
sierrafery's Avatar
Quoted: 246 Post(s)
Measure voltage against earth on the red and blue wires in C200 white 4 pin connector(attached) with side/fog lamps switched on, if you get 12V your problem might be in the fusebox ar at it's connectors
My friends call me Fery
2000 Discovery Td5 ES manual
Hawkeye v.6, Nanocom EVO,
VDM UCANDAS, oscilloscope
sierrafery is offline
post #3 of 5 (permalink) Old 02-15-2019, 09:00 PM Thread Starter
Quoted: 1 Post(s)
G'day sierrafery, thanks for responding.
I'll give that a try, I've been trying to avoid the rat nest in behind the fascias😝
Just so I have it right, if those wires show 12v with the parkers on, then the problem is most likely further downstream?
One thing I didn't mention, the park light bulbs have been going black for a couple of years, which I was told is a poor earth connection, but the tail lights are clear and do not display this. If it was the case, wouldn't every bulb on that circuit display the blackening?
post #4 of 5 (permalink) Old 02-15-2019, 10:55 PM
sierrafery's Avatar
Quoted: 246 Post(s)
I think so cos on the brown'purple wire the feed goes up into the switch then on the red and blue the feed is coming out from the switch for rear fogs and side lamps... after that connector the feed goes directly into the fusebox and splits within it between the side lights and fogs so if you have feed there but not on the fuses then IMO the best would be to swap the fusebox with a known good one to rule it out before you start chasing wiring issues which can be a nightmare
post #5 of 5 (permalink) Old 03-02-2019, 06:44 PM Thread Starter
Quoted: 1 Post(s)
Thanks for being the one willing to help sierrafery.👍
Turns out the solution was embarrassingly simple.
When installing the original switch with an aftermarket one, for some reason I neglected to solder one connection and had just twisted it together and it had come apart but not pulled out of the installation tape.
All good on that front, now I can go mad trying to work out why my airlocker compressor is blowing fuses.
Old Landies are a hobby tinkerer's dream🙄
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Passenger side rear door gremlins, lock and window vader wagon Discovery Series II 0 05-16-2009 08:21 PM
Help! lighting gremlins! AZROVER Discovery Series I 2 12-05-2008 05:50 AM
SLS Gremlins Come and Go KRWat Discovery Series II 3 09-12-2008 08:50 PM
Got Radio Gremlins!! ARGG!! LANDY96 Range Rover Classic 6 10-30-2006 12:37 PM
Gremlins in the Idle Piobre Discovery Series I 0 07-01-2005 03:40 PM
You may post new threads
You may post replies
