how to check cv axel? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 05-27-2011, 05:12 PM Thread Starter
Classic4Me's Avatar
Quoted: 2 Post(s)
Garage
I have feeling that my front right CV axle is broken because my truck wobbles badly at higher speed left turns. My rover also seems to only be one-wheel drive when i go off roading. I appears that the front left wheel is always doing all the work when offroading. Whats the best way to check the operation of the CV. Is it the same way to test the viscous coupler?
1990 RRC Portofino Red, 234K
SOLD
1995 RRC SWB Alpine White
GDE Bumper, Hella HID's, Dif Guards, 2" OME lift
Classic4Me is offline
post #2 of 10 (permalink) Old 05-28-2011, 06:41 PM
cdb
Quoted: 0 Post(s)
Unless you have aftermarket lockers and are locked, only one wheel per axle is driven.
cdb is offline
post #3 of 10 (permalink) Old 05-29-2011, 11:22 PM
qwaszxpolkmncvb's Avatar
Quoted: 0 Post(s)
Same goes with the non locking center differential. Hope you didn't get stuck out in the desert. Power to the front and rear axles act the same as a single limited slip axle. How's the paint coming along Classic?
qwaszxpolkmncvb is offline
post #4 of 10 (permalink) Old 05-30-2011, 03:53 AM
Quoted: 11 Post(s)
There are a few different ways to test fro this-seeing as how no one answered the question.
First off, find an empty parking lot, begin driving in ever-decreasing radius circles, clockwise, anti-clockwise. If at one point, you encounter a repetitive clicking from one front side or another, straighten the wheels and head for home as repeating this will eventually cause the CV joint to explode and cost more.
If while you;re doing this, it seems as though one wheel is skidding around the corners (outside wheel most likely) it is an indication of a viscous coupler problem.
Lastly, if one remove the front wheels and "hub" caps, and grabs ahold of the exposed CV joint axle, if you can pull it toward you, it's likely you've got a problem on that side.
I've probably got all the parts you'll need to put it back together, new/used.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
PTSchram is offline
post #5 of 10 (permalink) Old 05-30-2011, 08:05 AM
Quoted: 0 Post(s)
Figured you'd have a blunt answer.
I honestly hardly ever notice the front axle pull. I've felt it boogieing out of a wash but as far as driving slow out of sand from a stop it's the LR the wheel doing all the work. Seems the RF wheel pulls if it ever kicks in. Hard as hell to drive straight when it does.
post #6 of 10 (permalink) Old 05-30-2011, 10:51 AM Thread Starter
Classic4Me's Avatar
Quoted: 2 Post(s)
Garage
I took the wheel off the front right wheel, and noticed the dust cap was missing. I tried pulling on the end of the cv, and it moved about 1/16th of an inch. Was i supposed to take off the flange that the dust cap was attached to in order to properly diagnose this? If it is indeed broken what are your prices, shipped to scottsdale, AZ 85254? Im gunna go test for clicking in the parking lot right now.
Nope, i was able to get out . I havent been able to continue on with painting (or working on it too) my truck because i broke my hand two weeks ago, so paint production has come to a halt. I could continue on but, that could comprimise the quality of my work.
SOLD
post #7 of 10 (permalink) Old 05-30-2011, 11:56 AM
Quoted: 11 Post(s)
At least I'm consistent.
Nobody answered the poor man's question, somebody had to do it.
1/16" isn't too bad and probably not excessive.
Can't quote pricing until we know what's broken-if anything. I know it's uncommon, but I don't wanna sell somebody something they don't need. First off, I've probably spent the $ and don't wanna have to refund the $ and I just don't like to do business pushing stuff somebody doesn't need.
260-804-0458
PTSchram is offline
post #8 of 10 (permalink) Old 05-30-2011, 02:21 PM
roverandom's Avatar
Quoted: 4 Post(s)
If you suspect the CV's at all the best bet is to pull it apart and take a close look. It is a simple job.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline
post #9 of 10 (permalink) Old 05-30-2011, 03:02 PM Thread Starter
Classic4Me's Avatar
Quoted: 2 Post(s)
Garage
Ok, i just got back from testing out the truck.
When i had the wheel cranked all the way going in a circle Counter & anti clockwise, the front right wheel area of the car was making a popping/grinding sound. It didnt really sound like a clicking noise though. It only came from the right side, not on left at all.
This is unrelated but either one of the FL tierods or FL radius arms bushings has failed and makes a clunking noise while turning the steering wheel.
I want to take the wheels off my truck again so i can further inspect my CV, i might have to wait a couple days, since i will require some assistance given my circumstances.
SOLD
post #10 of 10 (permalink) Old 05-30-2011, 06:39 PM
roverandom's Avatar
Quoted: 4 Post(s)
Yeah, take it apart.
Matt.
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Need one Axel front right Disco 2 canadianDisco2owner Land Rover Parts and Vehicles Wanted 1 10-22-2009 08:18 AM
possible leaky axel or brakes papabeefis Discovery Series II 2 10-12-2009 03:51 PM
Rear Axel leak CademiaX Discovery Series II 2 04-09-2009 10:12 PM
Axel distances? Moeras Series Land Rovers 1 11-16-2005 03:29 PM
24 spline axel siam Accessories 0 10-05-2005 05:00 PM
You may post new threads
You may post replies
