Intermittent Sluggish motor - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 11-09-2016, 11:17 AM Thread Starter
crazyguy's Avatar
Quoted: 1 Post(s)
Hi All,
I've had a problem for quite some time that I'm at a loss at. My basic problem is that once my motor has warmed up (90 classic swb with a 4.2 bottom end, 3.9 top end) it will sometimes start "missing" when stopped at a stop light. The tach will drop to about 500rpm it seems. If I try to pull away normally, it will have very little power- but will move. Sometimes it will correct itself and lurch forward under power. Sometimes it does not. If I floor the gas pedal- it will clear up 100% of the time. If I release the gas and repress, it will fix the problem about 1/3 times.
If I sit at a light long enough while it is doing this, and it doesn't happen at every light, sometimes the ecu seems to adjust to give it more fuel and it runs perfect.
-If I unplug my MAF, the truck runs perfect 100% of the time, just really rich.
I've had it hooked up to rovergauge and found that at idle, my iacv reads 0-3% generally. I get up to 40% on that when running the truck hard. One other curious note about rover gauge is that I get no reading for target idle.
Here's what I have done.
-replaced IACV
-replaced all temp sensors
-tried out multiple maf's that are known working.
-changed out t valve
-changed out multiple vaccuum lines
-installed genuine 02 sensors
-new battery
-new coil
-cleaned and checked grounds on engine
-adjusted base idle per rave
-checked for tps function, and checked with known unit
-cleaned IACV seat and lubricated.
-cleaned butterfly
-replaced Ignition amplifier
-replaced plugs and installed 8mm wires
-tried to test a new junkyard ecu, same problems but unknown quality of unit. I've opened mine up and it looks fine, but looks can be deceiving.
I think that's about it, I've done pretty much everything I can think of. Any help would be greatly appreciated.
crazyguy is offline
post #2 of 2 (permalink) Old 11-20-2016, 06:42 AM
mikieman's Avatar
Quoted: 5 Post(s)
Garage
ill take a stab at it... have you replaced the fuel filter?
and maybe try adding some seafoam to the gas .. then let it go a bit... then some injector cleaner....may be a fuel problem...
im an american i dont speak english
1991 range rover
now parts
92 LSE
mikieman is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Linear Mode Linear Mode
Sluggish Fuel Gauge CT1997D1 Discovery Series I 1 07-23-2010 09:25 PM
95 RRC SWB Feeling Sluggish jcw000 Range Rover Classic 1 08-20-2009 06:56 AM
Disco II Sluggish when I accelarate SafariDave Discovery Series II 2 12-22-2008 05:52 AM
Sluggish at 60kmh skrams Discovery Series II 9 01-20-2007 05:57 PM
sluggish uphill guitar588 Discovery Series II 5 10-20-2005 09:38 PM
You may post new threads
You may post replies
